Not responding after wake up from hibernation
[Solved] Not responding after wake up from hibernation
Marcel Benček
(@marcel-bencek)
I frequently use hibernation (power off sleep) and PrusaSlicer 2.9.2 always hangs (No response) on wake up, without any chance to continue slicing and app restart is needed.
OS: Edition Windows 11 HomeVersion 24H2 Installed on ‎8. ‎11. ‎2024 OS build 26100.4202 Experience Windows Feature Experience Pack 1000.26100.107.0
HW: Processor AMD Ryzen 9 5900HX with Radeon Graphics 3.30 GHzInstalled RAM 64,0 GB
Does anybody have similar experience or no problems with wakeup from hibernation?
This topic was modified před 5 months by Marcel Benček
Napsal : 11/06/2025 7:28 am
RE: Not responding after wake up from hibernation
I use a Dell inspiron i7 Laptop, with windows11 and regularly have Prusa slicer open (4 sessions open today)
Last night I was using the computer in bed, on Battery, when I Finished doing emails and forum moderation, I simply closed the computer lid, put it somewhere safe, and went to sleep, (the laptop is set up to hibernate when running on Battery and the lid is closed)
today, I Opened the laptop, saw your post and checked that Prusa slicer was still working! no problems, all four sessions still available. they had all been sliced, so I moved a component in each session, and was able to re slice immediately.
as you can see, the power settings put my laptop into hibernation automatically.
I have just manually activated hibernation and woken it up again, and it worked fine...
Not sure if this helps...
Napsal : 11/06/2025 8:45 am
1 lidem se líbí
Marcel Benček
(@marcel-bencek)
Thank you for your reply, well it helped me in a sense that there are users that don't experience the problem I do, but it didn't solve my problem in a slicest. Anyway it's a move forward.
Napsal : 17/06/2025 8:01 pm
Marcel Benček
(@marcel-bencek)
SOLVED
After months I discovered that Graphics drivers of different version - a stable one - solved the problem of freeze after hibernation.
Graphics drivers were the cause. SOLVED
This post was modified před 1 month by Marcel Benček
Napsal : 09/10/2025 7:47 am
1 lidem se líbí
