No change applied on slicing
JFRivard
(@jfrivard)
I use Prusa slicer version 2.4.2.  When I open a STL, 3MF or OBJ files and make some adjusments, it does not apply on slicing.  The files has been made using Autodesk Fusion 360, free personnal version.
I'm I doing something wrong ? Is it a problem with the slicer or the files ?
Any advices ?
Thank you.
Napsal : 27/08/2022 1:49 pm
Please post a simple example for us to test.  Your file must be zipped to post correctly.
Cheerio.
Napsal : 27/08/2022 2:16 pm
After making your changes, did you click on Slice Now, or did a Ctrl-R, or File→Slice now? Or turn on Configuration→Preferences→Background processing.
It certainly has nothing to do with Fusion.
Actually, it just occurred to me that "making adjustments" can mean a number of things. I was thinking about adjustments within the slicer, to your print or filament settings. But I guess it could also mean making adjustments to the model itself. In which case, you'll need to right-click on the model and select Reload from disk with the new STL.
Napsal : 27/08/2022 5:01 pm
