Need help to Gcode - I can not figure it out myself.
Stonefox
(@stonefox)
At point 1:lift Extruder10 mm over heatbed and extrude 15 mm filament.Then go to point 2: and make a long (thick and high) line as shown in the picture.
My problem is that at the moment only that line is made at point 2, and since it is thin and very low, it is always a problem to remove it when I clean the plate.
sorry for my bad English--
Posted : 02/02/2022 3:30 pm
RE: Need help to Gcode - I can not figure it out myself.
You may want to look at @Bobstro's notebook, in particular the section on custom gcode and the prime line: https://projects.ttlexceeded.com/3dprinting_prusaslicer_start_gcode_mk3.html#prime-line
I have been using a variation on that theme for a long time to great success.
Posted : 02/02/2022 9:19 pm
Stonefox
(@stonefox)
Because of my bad english I don't know Thich one I shall use  as "Start Code " and "End Code"
Posted : 03/02/2022 12:05 am
Start gcode
Posted : 03/02/2022 12:24 am
