Multiple STLs lose relative positions
Jim Gurley
(@jim-gurley)
I'm the first to admit I'm new to multi-color printing and this slicer.  I'm actually using the Bambu Labs version, although I think it tracks revisions.
I have an object in Autocad that it essentially a "front panel" and it includes shallow text in a contrasting color.  When I create two STLs (the panel itself with sunken text, and the text that brings the surface back up), importing to the slicer loses their relative position.  I can move them around until I think I have them where they want to be, but it's an onerous process, and it's easy to miss by a bit.  I did a version where I used the slicer text tool to create my text, but re-doing that every time I update my design is also pain.  Is there a way to have the STL files maintain their spatial relationship?  I've also tried exporting the whole thing as a single STL, but that means re-coloring the triangles every time.
Posted : 09/02/2024 8:49 pm
RE: Multiple STLs lose relative positions
Save all parts  for one model,
Add the first part(one which touches the build plate) to the build plate,
Right click on the first part, choose Add Part>Load, and add the next part using the load option...
they should self align.
Add the rest of the parts in the same manner.
Posted : 09/02/2024 8:56 pm
Jim Gurley
(@jim-gurley)
That didn't help, although the fact that my design is in mils and I'm scaling after loading - it might have something to do with that?
Posted : 09/02/2024 9:03 pm
can you create a zip file with your parts in it, and load the zipfile, for us to have a look at?
when you say mils do you mean millimeters?
if so,  what are you scaling the dimensions to?
Prusa slicer is designed to work in millimeters
Posted : 10/02/2024 10:43 am
Jim Gurley
(@jim-gurley)
panel
When I said mils, I meant the original work is in units of .001 inch (since the PCB design program uses mils since most footprints are in those units).  I've attached a version that I pre-scaled in AutoCad to be in millimeters.  The text is thicker than required because I was originally fooled into thinking it was too thin, rather than slightly mis-registered when I last printed it.
Maybe Autocad fixes the origin of an exported STL at an extremity of the specific object, in which case I could add small registration objects outside the model?
Posted : 10/02/2024 1:47 pm
miroslav.h4
(@miroslav-h4)
Posted by: @jim-gurley
What JoanTabb writes is fine and works. Your model should already be created from the modeling program so that it does not need any scaling in Prusaslicer. This usually breaks all the dependencies of the parts of the model on each other.
This post was modified 2 years ago by miroslav.h4
Posted : 10/02/2024 4:56 pm
Jim Gurley
(@jim-gurley)
Scaling in Autocad doesn't help.
Posted : 10/02/2024 5:01 pm
Hi Jim,
you were correct, the relationships had been broken at some stage
the files you sent, were a front panel with cutouts for the letters, and a set of letters to fill the cutouts.
If you were planning to do these parts as separate entities they don't need to line up
When using Prusa Slicer, there is a little used option, where you can use a modifier, to insert parts of a print, without cutting holes...
Which makes lining up components Much easier...
So I have blanked the cut outs, in the main panel
You appear to have a single colour printer, Artillery Sidewinder...
I was wondering how you intended to print the model
I have created three  project files for you
Blank Panel.3mf   is just the blank panel and the letters, lined up in position (Needs Lots of Supports)
(Note, the letter strokes are very narrow and didn't want to resolve using a 0.4mm nozzle, so I used XY Compensation, to artificially widen the letters)
Blank Panel Multicolour       is the same file, set up, as I would set a prusa, for manual multicolour  (Needs Lots of Supports)
Blank Panel Face down    is the same panel printing in it's face so  hopefully you will get a good finish off the build plate surface, and you will need less supports
hope this helps
Joan
Posted : 10/02/2024 6:05 pm
Jim Gurley
(@jim-gurley)
I have a Bambu A1 - no idea where the other model type came from.  Thanks for all your work  - I'll give it a try in the next day or so.  I don't think I understand the "one part or multiple parts" question when I load the model.
Posted : 11/02/2024 12:25 am
Jim Gurley
(@jim-gurley)
I designed the part to be printed face down - no support is needed - all the overhangs have 45deg corbels (or whatever the right name is).  I wanted to print it as one part.  I can make the text a little bigger although Autocad isn't the easiest tool!
I now realize that if I load as separate parts, if I place both face down on the plate before trying to line them up, I only have to move the text in 2D since it sticks to the print surface.
Posted : 11/02/2024 12:45 am
Have a play with XY Compensation, for the TEXT,
It artificially increases the dimensions in the X and Y directions.
this can be particularly helpful if you have varying line thicknesses (Like Times Roman) where the thin sections may be too thin to print.
Posted : 11/02/2024 11:29 am
Jim Gurley
(@jim-gurley)
I don't see an XY compensation function.  The text objects aren't "text", as Autocad forces you to explode text and extrude it to make 3D objects.  I really should move to a more modern CAD program, but after 40 years of use, it's difficult for a very occasional user.
Posted : 11/02/2024 4:59 pm
XY Size Compensation is under print settings, advanced,   in Expert Mode
and it works with any STL
Posted : 11/02/2024 9:16 pm
