Multimaterial/-color: Prusaslicer wants to "transfer" or "discard" changes when switching between extruders
Hey lovely people,
there is an annoying thing when I switch between extruders in Prusaslicer and want to make changes to the filament's settings.
If I want to make changes to a setting for just ONE print, like decreasing the print temperature and then switch to a different extruder it always asks me to "transfer", "discard" or "save settings", none of which I want. I just want the settings to be there for that single print.
Is there a way to make those temporary changes to e.g. filament temperature?
Thanks all! 🙂
RE: Multimaterial/-color: Prusaslicer wants to "transfer" or "discard" changes when switching between extruders
You are making temporary changes. That dialogue box is a little strange but it's basically asking you if you want to save the settings you changed. Since you don't want to (because it's only for one print) you can safely choose discard and it will go back to the defaults for the next print.
