					                		Multi material support #feature request - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/</link>
                <lastBuildDate>Wed, 15 Apr 2026 19:57:25 +0000</lastBuildDate>
                        <title>RE: Multi material support #feature request</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640211</link>
                        <pubDate>Sat, 04 Mar 2023 11:02:09 +0000</pubDate>
                        <description><![CDATA[With the Multimaterial unit you can even define different filament for infil and perimeters on a featureon this setup, the outline for the letters is set to black, whilst the infill is white...]]></description>
                        <content:encoded><![CDATA[<p>With the Multimaterial unit you can even define different filament for infil and perimeters on a feature<br /><a href="https://forum.prusa3d.com/wp-content/uploads/2023/03/IMG20230303084615-scaled.jpg"><img class="alignnone size-medium wp-image-150886" src="https://forum.prusa3d.com/wp-content/uploads/2023/03/IMG20230303084615-600x500.jpg" alt="" width="600" height="500" /></a><br />on this setup, the outline for the letters is set to black, whilst the infill is white,    which makes the letters 'Pop' <br /><br />regards Joan<br /><br /></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640211</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640208</link>
                        <pubDate>Sat, 04 Mar 2023 09:32:56 +0000</pubDate>
                        <description><![CDATA[🤯wow. Thanks for your help. I will try this. Is there also something similar for infill? Expensive outer wall material and cheap infill material?]]></description>
                        <content:encoded><![CDATA[<p>🤯wow. Thanks for your help. I will try this. Is there also something similar for infill? Expensive outer wall material and cheap infill material? </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Matze Jo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640208</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640200</link>
                        <pubDate>Sat, 04 Mar 2023 08:27:26 +0000</pubDate>
                        <description><![CDATA[Yes.  Under Print Settings&gt;Multiple Extruders&gt;Extruders you can assign which extruder is used for various features.  There are both Support Material and Support Material Interface opti...]]></description>
                        <content:encoded><![CDATA[<p>Yes.  Under Print Settings&gt;Multiple Extruders&gt;Extruders you can assign which extruder is used for various features.  There are both Support Material and Support Material Interface option there.   Its a Yellow setting so you must be in Advanced mode to see them.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640200</guid>
                        <title>Multi material support #feature request</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640194</link>
                        <pubDate>Sat, 04 Mar 2023 08:00:10 +0000</pubDate>
                        <description><![CDATA[Is it possible to create supports out of two materials? PVA Filament is suprisingly expensive and i would like to use it only on contact points to the surface of my part.]]></description>
                        <content:encoded><![CDATA[<ul><li>Is it possible to create supports out of two materials? PVA Filament is suprisingly expensive and i would like to use it only on contact points to the surface of my part. </li></ul>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/multi-material-support-feature-request/#post-640194</guid>
