MK4+MMU3 - force each part to print the selected color in its entirety
gwallace41
(@gwallace41)
I created this .step file with 4 objects.  the name, 2 logos and the body.  when I slice the object the text will be completely black through all layers needed.  However the 2 logos will only print in white on the top layers that are above the body.  the first picture I backed the layers down to show that it even seems like the slicer is coloring those objects in green like the body.  the third picture is the printed part that only printed the top layer.  I would like for the surface to be flat.  Is there setting in Prusaslicer that forces each part to be completely the color set in the config?
Napsal : 04/12/2024 10:46 pm
gwallace41
(@gwallace41)
RE: MK4+MMU3 - force each part to print the selected color in its entirety
Solved my own problem.  The issue was not with Prusa Slicer.  The issue was with the CAD file I created.  I needed to create copies of the parts and then use those copies to "Engrave" the base item.  This created a negative area in the body for the other parts to sit in.
Napsal : 05/12/2024 3:12 pm
1 lidem se líbí
