MK3S PrusaSlicer PLA and PETG Settings
Zeehel
(@zeehel)
Hey, I hope anyone can give me an answer.
Is it somehow possible to tell the printer or Prusa Slicer the adjustment for the different filaments?
I mean I got a Z-setting of -0.8 for PETG and when I want to print PLA I have to manual adjust this setting to -0.9 or is there an easier way?
Publié : 03/08/2020 3:25 pm
Holck
(@holck)
RE: MK3S PrusaSlicer PLA and PETG Settings
There is an older thread here:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/different-filament-starting-z-heights-gcode/
Easiest seems still to be to to make a separate printer profile for PLA and PETG with z offset set differently. that will work directly in the slicer.
Or you can use the sheet menu on the printer screen menu, and make a preset for PLA and PETG on your type of sheet. You can have 6 presets here as I remember. Very quick to change your preset from the menu, and each have a different live Z
Ce message a été modifié il y a 5 years par Holck
Publié : 03/08/2020 7:23 pm
tj
 tj
(@tj-2)
Makes me wonder why you need different z offsets based on material.
I mean, the nozzle height over the build plate don't change when you change material, so i wonder if you are trying to compensate for a completely different problem.
Publié : 08/08/2020 11:26 am
Posted by: @torbjorn-j3
I don't personally. I've found that calibrating the extrusion multiplier for each filament has resolved most of the related issues. I may tweak Live-Z as I observe the first layer, but that's about it. Most of the time, I don't bother.
Publié : 08/08/2020 1:41 pm
tj
 tj
(@tj-2)
@bobstro
makes sense to have to adjust extrusion multiplier based on material yes. i assumed it was the offset (z offset under printer settings) to make first layer thicker or smaller based on material.
for me once i have the first layer height dialed in via live z adjust it works well for both pla and petg.
Publié : 08/08/2020 5:40 pm
