Missing supports
Ian
 Ian
(@ian-10)
Missing supports
I am trying to slice the cookie.stl from this:
https://www.thingiverse.com/thing:3598919/files
It is intended by the designer to be printed with the pattern "up" and supports in the underside which will be removed and covered by the "filling" part. However when I slice the part, no supports are added irrespective of which setting I use or if I paint enforcers as well.
I am using PruserSlicer 2.3.0+
Thanks
Ian
Postato : 10/02/2021 9:12 pm
RE: Missing supports
Are you turning supports on?
the top RED line in the image above turns support generation on,
the Middle Red Line, helps make the supports more easily removable, and
the bottom Red Line, causes support all over the underside of bridges, if it is ticked the centre of bridges will be unsupported.
Postato : 10/02/2021 9:27 pm
1 persone hanno apprezzato
The secret here is to unselect "Don't support bridge infill".
Postato : 10/02/2021 10:49 pm
Ian
 Ian
(@ian-10)
I had to UNTICK "Dont't support bridges" to get it to generate supports correctly.
Thanks
Postato : 11/02/2021 7:25 am
Utenti
Did the last comment fix your problem?
Postato : 13/02/2021 2:51 am
Ian
 Ian
(@ian-10)
Yes, thank you
Postato : 15/02/2021 7:23 am
