Minimum layer height for internal bridging
Thingy
(@thingy)
When printing with a larger nozzle, 0.5mm and up, and having a low (perimeter) layer height 0.1mm, the extruded material is so little that bridging fails completely and just deposits a small amount of fileamnt at the edge es of the hole.
Using combine infill doesn't use this setting for internal bridging, ie covering holes that have infill on top of them.
Or even with regular noncombining inill layers, a setting that the first bridge layer should have a certain minimal height, would help a lot.
Napsal : 12/10/2024 8:28 am
That sounds right, use a thicker layer height.
Napsal : 12/10/2024 11:24 am
Thingy
(@thingy)
RE: Minimum layer height for internal bridging
That is not a solution, that is a workaround. And it would look terrible.
Napsal : 12/10/2024 2:38 pm
Tough.
If you want optimal performance from a low layer height you must use a smaller nozzle.
Napsal : 13/10/2024 3:26 am
Thingy
(@thingy)
That is so true, some prints though, like spheres, that have low resolution in xy, but gets a boost by higher z-resolution. And I'd prefer to print those in halves with a square connector part. Great as a guide when you glue them halves together under pressure.
Now I could print a large sphere with a 0.2 nozzle, but god damn that would take time.
This was just an example, there are other objects that has similar properties.
Napsal : 13/10/2024 12:02 pm
Like many high precision parts the better answer is to print slighly oversize and machine to fit.
Bu not your time, machine time, if it matters you can add another printer.
Napsal : 13/10/2024 4:09 pm
Thingy
(@thingy)
Still not an answer, just workarounds. And adding another printer would half the time to print two objects, not one. But in the example I mentioned the equation is valid, since it comprised of two half-spheres.
And also, this would double the electricity cost and space needed. And since very few in the reprap community is working with this in a factory/workplace setting, space is at a premium (most likely a part of living space).
Napsal : 13/10/2024 9:40 pm
Correct, it is a workaround - we are regrettably unable to use magic.
Napsal : 13/10/2024 10:05 pm
Thingy
(@thingy)
That's seriously too bad, but in all unseriousness, a slicer sometimes feel like magic.
Napsal : 05/06/2025 8:40 pm
Sembazuru
(@sembazuru)
Have you tried turning Thick Bridges on?
Unfortunately, you can only set that at a full print or as a setting for the full object. It doesn't show as a setting for a part or a mesh modifier.
This post was modified před 11 months by Sembazuru
See my (limited) designs on:
Napsal : 05/06/2025 9:31 pm
Thingy
(@thingy)
Actually I have not, I didn't consider the possibility that first top layer infill was treated as a bridge. If it is, then also the bridge flow ratio might affect the output. Right now I'm using a much smaller tip so it hasn't been an issue for a while.
It's also possible that that setting wasn't available when I asked the question originally. (PrusaSlicer 2.2, I believe)
It's a case of ego-bias, "I am using a large tip at insane layer height so everyone does", hence I was confounded when the slicer hadn't an option for this.
Napsal : 05/06/2025 11:04 pm
MyocardialInfatuation
(@myocardialinfatuation)
It is great privilege to join your community thank you for adding.
Good see how respectful and how professional the experts treat members.
- P
Napsal : 24/12/2025 5:33 am
