Manually typing '0' into position for "object manipulation" panel fails if you use enter key
Ken Burkhart
(@ken-burkhart)
When typing any value that isn't 0, and then pressing enter, the value applies.  However, (based on habit), if you put 0(zero) and hit enter, the value reverts to whatever it was before most of the time.  You can get around this by tabbing or clicking on a different box, but its annoying that hitting enter makes the value revert.
Its not a deal breaker, but I DO consider it a bug that could be worth looking at some time and hopefully fixing.
Best Answer by Neophyl:
Theres already been multiple issues raised on github about this.  What version are you running ? I just tried positions with zero in them and hitting enter after with 2.2.0 and it accepts them ok which should be right as I thought they had fixed that in 2.2.0
Opublikowany : 26/04/2020 8:09 pm
RE: Manually typing '0' into position for "object manipulation" panel fails if you use enter key
Opublikowany : 26/04/2020 9:25 pm
Ken Burkhart
(@ken-burkhart)
I have 2.1.0, I'll be updating to 2.2 today since I just today saw that there was an update.  Usually the program notifies me when there is an update so I'm not sure why I haven't gotten that notification.
I'll update right now and see if it shows as fixed on my end.
Opublikowany : 26/04/2020 9:29 pm
Ken Burkhart
(@ken-burkhart)
@neophyl
Its not letting me edit the previous reply(maybe because its waiting on moderation approval).  The update did indeed fix the issue.  I've marked your answer as "best answer."  Thanks!!!
Opublikowany : 26/04/2020 9:46 pm
Hi  Kenneth, it's not a Moderation timer, the edit time window is quite short,
Opublikowany : 26/04/2020 10:29 pm
Ken Burkhart
(@ken-burkhart)
@joantabb
Thanks for the info.  I thought it simply wasn't allowing me to edit to to it waiting on mod approval.  Now I know.
Opublikowany : 26/04/2020 10:31 pm
