MacOs 10.14 MBP17 2010 and Slicer 2.8.0 Issues
Johannes
(@johannes)
Hello
No Problems at all up to 2.7.4
2.8.0 GUI performance in Edit is sometimes retarded, Preview is barely responding at all and shows nothing onto the printbed.
Stepping back to 2.7.4 causes confusion with a database-pointer to user/library/.../Preferences.framework. Starting up only out of the terminal-icon inside the packet and hangs up while importing an .stl.
THX 4 Help.
Best Answer by JimB:
Where can I download 2.7.4 for Mac?
https://github.com/prusa3d/PrusaSlicer/releases
Scroll down till you get to the version you want and then expand the Assets.
Posted : 10/07/2024 8:28 am
Johannes
(@johannes)
RE: MacOs 10.14 MBP17 2010 and Slicer 2.8.0 Issues
Solved the downgrade issue (thx prusa forum): newer version must be close. let newer software sit where it is. extract older dmg to a diffent folder. open older version and select or create a working konfiguration file. close old version. remove newer version and stuff with its parent folder. move older version´s parent folder to its folder structure of your choice. done.
Posted : 10/07/2024 10:13 am
Grijspetje
(@grijspetje)
Hi all,
I upgraded to 2.8.0 and have an issue with the g-code generation which takes ages..... sometimes even hang my macbook pro ( the no crossing perimeter is not enabled). I'de like to downgrade to 2.7.4. which gave me no problems at all. I really regretted the upgrade. Where can I download 2.7.4 for Mac?
Thanks for the help!
kind regards, Peter
Posted : 14/07/2024 9:47 am
JimB
 JimB
(@jimb)
Posted : 14/07/2024 7:34 pm
Johannes liked
