M600 parking position
I am trying to use the add color change in prusa slicer. The print pauses at the point I tell it but I get an error that it is trying to move out of range. Is there somewhere in prusa slicer I can specify the parking position or is it all on the printer firmware side?
I am not seeing anywhere in prusa slicer but maybe I am just missing it.
RE: M600 parking position
descriptions for many Gcodes can be found in the RepRap Wiki
the link below should take you to M600
https://reprap.org/wiki/G-code#M600:_Filament_change_pause
there will be default settings in the printer firmware, however you can revise the activity of M600 using custom Gcode if required.
