Lightning infill doesn't work well on large object
I tried using the new Lightning infill to reduce print time and material used. It seems to not work well on objects where the volume to fill is large. As the layers stack up, the infill becomes more and more wobbly as it has little support. Because of the movement, the layers don't adhere well together, only making the problem worst.
I was also surprised by the slicing, which started the infill from only one side of my volume, making it extend much further than it could have on the other side:
Postato : 18/11/2022 8:11 pm
