Issue slicing multiple printer heads ( CHANGING COLORS ON SLICE)
Ben Mansker
(@ben-mansker)
As the picture shows, when I slice it makes areas change heads and puts lines in the print. Does anyone knw how to fix this issue? Im using a GEEETECK Mizer M with default setting.
Posted : 04/03/2024 3:50 pm
BaconFase
(@baconfase)
RE: Issue slicing multiple printer heads ( CHANGING COLORS ON SLICE)
Especially because of your third example in your image, I assume you're not using the 2.7.2 slicer. That type of issue should have been fixed by the latest slicer update.
Posted : 04/03/2024 10:40 pm
Ben Mansker
(@ben-mansker)
Sadly that is not the case. I am currently using 2.7.2 and it was also the same for the previous version.
Posted : 05/03/2024 2:10 pm
