Is there Z hop
JimAndi
(@jimandi)
Is there Z hop
Hi all,
I am new to the forum and new to 3d printing. I have a Ender 3 printer and using the Prusa Slicer (love it). My question is there a setting in Prusa Slicer to set the Z hop?  My other slicer software starts with a "C" it has a z-hop to step over gaps in your modal, this is used in 2 color printing. If you print a sign, you print the words in one color and the body of the sign in another. Is there a setting?
Postato : 25/05/2020 4:32 am
towlerg
(@towlerg)
RE: Is there Z hop
Don't know about Z hop but printing two colour signs does not need it. See here  it's a long thread but well worth reading.
Postato : 25/05/2020 1:40 pm
RE: Is there Z hop
Printer settings->Extruder 1->Lift Z is the equivalent in PrusaSlicer.
Postato : 26/05/2020 4:42 am
2 persone hanno apprezzato
JimAndi
(@jimandi)
RE: Is there Z hop
@bobstro
THANK YOU!!!!
Postato : 26/05/2020 7:20 pm
D3DCreative
(@d3dcreative)
Z Hop override
@james-l-anderson
There are two places in PrusaSlicer that control the Z Hop.
Under the Printer Settings > Etruder 1 > Retraction:
Here you'll see Lift Z: is set to 0.4mm by default, however this is overridden by the filament settings.
Go to Filament Settings > Filament Overrides > Retraction:
Now tick the Lift Z checkbox and set the Z Hop height your require.
Hope this helps?
Dave
Postato : 13/10/2021 2:24 pm
3 persone hanno apprezzato
Jakob
(@jakob-2)
RE: Is there Z hop
@davegrant
Now everything makes sense, thank you 😀
Postato : 10/12/2021 1:30 pm
1 persone hanno apprezzato
D3DCreative
(@d3dcreative)
RE: Is there Z hop
Posted by: @jakob-2
@davegrant
A noob helping a noob 🧑🏼‍🎄
Postato : 23/12/2021 11:39 am
serenity
(@serenity)
RE: Is there Z hop
How do you determine how much z hop you need? is it just based on nozzle size?
Postato : 11/01/2022 12:52 am
Sp4rkR4t
(@sp4rkr4t)
RE: Is there Z hop
It's mainly based on the filament used, while larger nozzles can benefit from more Z-lift the type of filament has by far the greatest effect. I've never found a hard and fast rule on how much other than to keep it minimal.
Postato : 11/01/2022 9:35 am
candy man
(@candy-man)
Utenti
RE: Is there Z hop
Thank you for that answer I was having trouble finding it myself
Postato : 31/10/2023 10:48 pm
