					                		Is there overlap between lines in the walls/perimeters ? - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/is-there-overlap-between-lines-in-the-walls-perimeters/</link>
                <lastBuildDate>Fri, 08 May 2026 15:38:29 +0000</lastBuildDate>
                        <title>RE: Is there overlap between lines in the walls/perimeters ?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/is-there-overlap-between-lines-in-the-walls-perimeters/#post-546775</link>
                        <pubDate>Wed, 15 Dec 2021 18:19:27 +0000</pubDate>
                        <description><![CDATA[Found the answer, important to know for calibration of the extrusion multipliersometimes switch between Cura and Prusaslicer, does anyone know if Cura does this in the same way ?]]></description>
                        <content:encoded><![CDATA[<p>Found the answer, important to know for calibration of the extrusion multiplier:</p><p><a href="https://help.prusa3d.com/en/article/layers-and-perimeters_1748/" target="_blank" rel="noopener">https://help.prusa3d.com/en/article/layers-and-perimeters_1748/</a></p><p>I sometimes switch between Cura and Prusaslicer, does anyone know if Cura does this in the same way ?</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Gatze</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/is-there-overlap-between-lines-in-the-walls-perimeters/#post-546775</guid>
                        <title>Is there overlap between lines in the walls/perimeters ?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/is-there-overlap-between-lines-in-the-walls-perimeters/#post-546139</link>
                        <pubDate>Tue, 14 Dec 2021 12:31:43 +0000</pubDate>
                        <description><![CDATA[And I don&#039;t mean between infill and walls.
I&#039;m trying to calibrate my printer (sidewinder X1), already did the e-steps procedure and printed a test cube.
This is my &#039;rough and fast&#039; profil...]]></description>
                        <content:encoded><![CDATA[<p>And I don't mean between infill and walls.</p>
<p>I'm trying to calibrate my printer (sidewinder X1), already did the e-steps procedure and printed a test cube.</p>
<p><a href="https://3dprintbeginner.com/flow-rate-calibration/" target="_blank" rel="noopener">https://3dprintbeginner.com/flow-rate-calibration/</a></p>
<p>This is my 'rough and fast' profile, I print with a .6 nozzle with a linewidth of 0.75 and a height of 0.5mm</p>
<p>I would expect the walls of the testcube being 2x0.75 = 1.5 mm (2 lines of 0.75mm)</p>
<p>But they are smaller. When I see this in the slicer:</p>
<p><a href="https://forum.prusa3d.com/wp-content/uploads/2021/12/prusalinewidt.png"><img class="alignnone size-medium wp-image-117502" src="https://forum.prusa3d.com/wp-content/uploads/2021/12/prusalinewidt-600x242.png" alt="" width="600" height="242" /></a></p>
<p>Then my question is: is there some kind of overlap ? Because in the slicer is stated: 2 lines = 1.39mm and I expect 1.5mm ?</p>
<p>I can only find an overlap value between infill and walls, but not between lines in the walls or perimeters it self.</p>
<p>Hope the question is clear.</p>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/is-there-overlap-between-lines-in-the-walls-perimeters/#post-546139</guid>
