Is there a way to specify a neutral color?
I want to slice a multimaterial model for a colorful print. Some of the faces of the model will end up hidden from sight, so I don't care which color will be used to print them. Is there a way to tell PrusaSlicer that the material of specific surfaces doesn't matter, for example so it could minimize color changes or use these areas as buffer when swapping colors? Similar to how the material of infill is colored based on need?
Posted : 21/05/2022 8:50 pm
