Is there a way to reload original configuration for PrusaSlicer?
There probably is, but I don't recognize it. Over time, I have made a bunch of changes, or foolishly accepted some 3mf file changes. My last print has some defects, so I'd like to go back to the beginning. Is there a way to get back to all the default slicer settings for my printer (MK4 IS)? Thanks.
RE: Is there a way to reload original configuration for PrusaSlicer?
Just select a system preset from the dropdown, even if it has the (modified) suffix. You'll get prompted on how to handle any changes and you'd choose Discard to go back to default settings for that given preset.
XL-5T, MK3S MMU3 || Printing with multiple nozzle-sizes: Official Guide, Unofficial || PrusaSlicer Fork || Other advanced slicer tactics || TPU
Maybe, it depends on how far back you want to go. While you can go back to the system presets at any time, you are stuck with the current version of the system presets. Prusa update them over time. However when they do so they make a snapshot of the current ones on your system. You can go back to those using the menu. They o lay go back so far though. The other problem with doing that is a newer version of Prusa Slicer might have new settings for a new feature/function that aren’t actually in the old settings profiles so it will try and update if you restore the old ones.
