Incorrect export filename in 2.3.x
In recent versions of slicer, the file name of exported files changed, from the actual filename, to the name of the name of the body from the CAD software it was created it. So now, every single g-code file I export from Slicer is called "Body1.gcode". This is really annoying, since I will never change names of individual bodies in Fusion, just components. It makes sense that the feature to use body name as file name as export name was added but it makes no sense what so ever to me that the parameter is still called "input_filename_base" but is actually the body name. Just add a new parameter for body name and keep filename as it was...?
Respondido : 31/08/2021 12:44 pm
