how to scale models?
Henryhbk
(@henryhbk)
Alright, I may be going insane (or have always been so?) anyway, I have some CAD models I am making for a diorama. For ease of modeling I did the CAD model life size, figuring no problem, just scale down to the 1/35 scale of the model I am making (i.e.1/35 =  0.028571428571429 per my calculator). When I import it into prusaslicer 2.6 it auto-scales (yeah, it's huge compared to the printer) and then to make my math work, return it to 100% scale, and apply that decimal above, which prusaslicer rounds to 0.03. Fine, except the model is way, way to small (pretty sure below the capability of the mk4 if I somehow wanted it that tiny). Here is a shot with the scale factor applied... (that model is about 2m tall and 50cm thick in real life (it's in inches in CAD but just estimating). Am I doing this wrong (I can also work off dimensions to scale it, as I have one of these already in the real size I guess)
Opublikowany : 19/07/2023 12:12 pm
By default PS uses mm.  Are you set up in mm or inches ?  Natively its all metric so probably best to use that if you can.
Opublikowany : 19/07/2023 12:20 pm
Chris Hill
(@chris-hill)
RE: how to scale models?
If the numbers in your STL represent inches, and PrusaSlicer interprets them as mm, you'll just need to scale everything up by 25.4.
Opublikowany : 19/07/2023 12:45 pm
Usually you can set the export to mm or inch for all CAD systems. PS import is set to mm by default.
wbr,
Karl
Opublikowany : 19/07/2023 12:58 pm
Henryhbk
(@henryhbk)
thanks for everyone's input. Yes, I had set the output of OnShape to put out mm, although if i recall prusaslicer detects that and auto-converts., But either way, the model seems way smaller than the scale factor should make it (scaling should work either way
see attached image for the unscaled import (regardless of units) - note  the print bed in the screenshot for scale
Opublikowany : 19/07/2023 1:10 pm
Henryhbk
(@henryhbk)
OMG, I am such a an idiot. Gotta get more coffee, it's already a percentage not the decimal factor. Duh, so my scale was 2 decimal places off... 🙄 so it should be ~ 2.85 not 0.0285. none of you saw anything!
Opublikowany : 19/07/2023 1:23 pm
Chris Hill
(@chris-hill)
Er, yeah, we all saw that of course, but between us we agreed you'd learn best by finding out for yourself.  Ahem. 🙂
Seriously though, I've made the same mistake myself!
Opublikowany : 19/07/2023 1:42 pm
1 ludzie polubili
Henryhbk
(@henryhbk)
As I always tell my nurses, if you ever see me not drinking coffee, call a code-blue, I've probably died. During the pandemic when we weren't allowed to unmask at all in the hospital, I had a camelback with espresso that snaked under my mask (yes, 2L of espresso)
Opublikowany : 19/07/2023 1:46 pm
wbr,
Karl
Opublikowany : 19/07/2023 2:36 pm
