How to position nozzle to the middle of the bed based on bed_shape?
dma_k
(@dma_k)
Dear all,
Sorry for newbie question. I would like to position the nozzle in the middle of the bed (Y axis) based on bed size in custom printer G-code. I tried this but it didn't work:
G0 Y{rect_size/2}
In settings it displays that the variable name is rect_size but here it is said that none of rect_size, rect_size.y, rect_size.depth works. Just by co-insidence, when I looked at generated G-code, I found this:
bed_shape = 0x0,220x0,220x220,0x220
However here it is said that bed_size can not be used in arithmetic expressions.
Well, how one can do so? Thank you in advance!
Napsal : 22/11/2020 6:39 pm
RE: How to position nozzle to the middle of the bed based on bed_shape?
which printer?
Prusa is 250mm /210mm
how about
G1 X125 Y105
Joan
Napsal : 22/11/2020 9:41 pm
dma_k
(@dma_k)
@joantabb
Clear how to set the numbers manually: we all can divide by 2 😉
How to make this value computable?
Napsal : 25/11/2020 10:31 pm
can you use parse the variables rect_origin and rect_size, instead of  trying to use bed_size
Napsal : 26/11/2020 1:38 am
dma_k
(@dma_k)
@joantabb
I am a complete newbie in PrusaSlicer and got no idea how to parse rect_origin and/or rect_size. Have you got a ready-to-use receipt? I tried to search for anything on this forum, but with no results. I also see that PrusaSlicer does not dump either rect_origin or rect_size in resulting .gcode file, so I don't know what is the value for these variables.
Napsal : 26/11/2020 10:46 am
@dma_k
rect_origin is usually 0,0 on a cartesian printer,
rect_size relates the Max X and Max Y values, these are used internally within Prusa Slicer, and are not output to Gcode.
Prusa slicer must be able to access these values in order to place single items in the dead centre of the build plate, and to indicate when items exceed the build volume of the printer.
Napsal : 26/11/2020 11:27 am
dma_k
(@dma_k)
I was able to find a solution, but not via slicer. It requires recompilation of Marlin firmware. Define
#define NOZZLE_PARK_POINT { X_CENTER, Y_CENTER, 20 }
and then add
G27 P2
to custom end G-code.
Napsal : 09/01/2021 7:29 pm
