					                		How to increase gap between infill lines in first layer? - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/</link>
                <lastBuildDate>Sun, 07 Jun 2026 19:55:57 +0000</lastBuildDate>
                        <title>RE: How to increase gap between infill lines in first layer?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-730205</link>
                        <pubDate>Thu, 19 Dec 2024 16:45:36 +0000</pubDate>
                        <description><![CDATA[I don&#039;t think the original request is possible without postprocessing the gcode. But using a different filament might get the visual impact you want.For example, here is a print that I did a...]]></description>
                        <content:encoded><![CDATA[<p>I don't think the original request is possible without postprocessing the gcode. But using a different filament might get the visual impact you want.</p><p>For example, here is a print that I did and the side that is up was against the bed when printing. This is using Filament PM Silver (the type that used to be included with MK3 kits), and I printed with hilbert curve bottom fill pattern. The part feels smooth (because I printed on the smooth PEI plate), but the resulting visual pattern is almost holographic when viewed with stereo vision (i.e. two good eyes, instead of a photograph).</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/b5ed5048-img_20190706_014632.jpg"><img class="alignnone size-full wp-image-172616" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/b5ed5048-img_20190706_014632.jpg" alt="" width="554" height="300" /></a></p><p>I've had other filaments that have similar visual effects. I don't have a picture handy, but I've had similar results with a 2-color coextrusion filament that I have.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-730205</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729868</link>
                        <pubDate>Sun, 15 Dec 2024 16:24:20 +0000</pubDate>
                        <description><![CDATA[I don&#039;t know what print sheet you&#039;re using but the satin sheet tends to show the extrusions more than the PEI or textured.]]></description>
                        <content:encoded><![CDATA[<p>I don't know what print sheet you're using but the satin sheet tends to show the extrusions more than the PEI or textured.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Brian</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729868</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729832</link>
                        <pubDate>Sun, 15 Dec 2024 01:59:02 +0000</pubDate>
                        <description><![CDATA[Thanks for the suggestion!I think that would work except that it&#039;s a rounded shape and I need to keep the layers consistent and as thin as possible.Saying that I seem to remember a setting t...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the suggestion!<br />I think that would work except that it's a rounded shape and I need to keep the layers consistent and as thin as possible.<br />Saying that I seem to remember a setting to print infill at multiples of the layer height.. maybe there's something there.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>rosetter</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729832</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729787</link>
                        <pubDate>Sat, 14 Dec 2024 16:02:52 +0000</pubDate>
                        <description><![CDATA[Raise the nozzle on the first layer.]]></description>
                        <content:encoded><![CDATA[<p>Raise the nozzle on the first layer.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729787</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729778</link>
                        <pubDate>Sat, 14 Dec 2024 13:07:35 +0000</pubDate>
                        <description><![CDATA[Hi, thanks for the reply!I played around with this parameter and noticed that although it changed the extrusion width in the 3d preview, it also adjusted the density of fill lines to compens...]]></description>
                        <content:encoded><![CDATA[<p>Hi, thanks for the reply!<br />I played around with this parameter and noticed that although it changed the extrusion width in the 3d preview, it also adjusted the density of fill lines to compensate.  I haven't tried a real print yet.<br /><br />In some sense I'm trying to break things a little by introducing slight gaps.  It's probably a good thing that I'm having a hard time. :)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729778</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729748</link>
                        <pubDate>Sat, 14 Dec 2024 01:56:33 +0000</pubDate>
                        <description><![CDATA[I guess you may try and reduce the extrusion width for the infill pattern for the first layer. But I haven&#039;t tried it myself (or even contemplated it) so not sure what it would look like.]]></description>
                        <content:encoded><![CDATA[<p>I guess you may try and reduce the extrusion width for the infill pattern for the first layer. But I haven't tried it myself (or even contemplated it) so not sure what it would look like. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729748</guid>
                        <title>How to increase gap between infill lines in first layer?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729615</link>
                        <pubDate>Thu, 12 Dec 2024 12:44:05 +0000</pubDate>
                        <description><![CDATA[Hi, I quite like the infill pattern visible in the first layer of a print I&#039;m doing.  It&#039;s barely visible however, which I suppose is usually the desired behavior.Does anyone know a way to c...]]></description>
                        <content:encoded><![CDATA[<p>Hi, I quite like the infill pattern visible in the first layer of a print I'm doing.  It's barely visible however, which I suppose is usually the desired behavior.</p><p>Does anyone know a way to create a small gap between infill lines on the first layer and make the pattern more visible?</p><p>Thanks!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-increase-gap-between-infill-lines-in-first-layer/#post-729615</guid>
