					                		How to get rid of different support pattern for first layer - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/</link>
                <lastBuildDate>Mon, 13 Apr 2026 02:16:02 +0000</lastBuildDate>
                        <title>RE: How to get rid of different support pattern for first layer</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629294</link>
                        <pubDate>Thu, 08 Dec 2022 16:27:12 +0000</pubDate>
                        <description><![CDATA[Thanks for both of your replies! Bummer that this part is not adjustable. I get that using 90% gives better adhesion, but then I could just use a single layer raft. If I wanted to use the sa...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for both of your replies! Bummer that this part is not adjustable. I get that using 90% gives better adhesion, but then I could just use a single layer raft. If I wanted to use the same density my honeycomb uses, then having the honeycomb as 1st layer will give me best adhesion, least warp and better uniformity of the following layers.</p><p>In my case I don't want to use it as support, its going to be part of the model, kind of an infill but without bottom (I don't want a bottom there, just an open honeycomb, but I also can't model it solid and print it as infill without bottom because it needs the bottom in other places). </p><p>Thought using support with zero z-distance is a quick hack, but I can also model the honeycomb directly or take the time and setup my mk3s with cura (avoided this after buying a prusa printer, but after having used both slicers for a while, I feel cura has better options and user interface).</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>mrmilbe</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629294</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629251</link>
                        <pubDate>Thu, 08 Dec 2022 07:51:23 +0000</pubDate>
                        <description><![CDATA[Also to save files you have to ZIP them up first.  The forum is very limited in what types it allows.]]></description>
                        <content:encoded><![CDATA[<p>Also to save files you have to ZIP them up first.  The forum is very limited in what types it allows.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629251</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629250</link>
                        <pubDate>Thu, 08 Dec 2022 07:45:24 +0000</pubDate>
                        <description><![CDATA[You should be out of moderation now!regards Joan]]></description>
                        <content:encoded><![CDATA[<p>You should be out of moderation now!</p><p>regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629250</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629249</link>
                        <pubDate>Thu, 08 Dec 2022 07:43:41 +0000</pubDate>
                        <description><![CDATA[Sorry I can&#039;t spend a lot of time on your model this motning. It would appear that your model has a gap under it, and that gap is filled with supports, the lines are part of the supportI hav...]]></description>
                        <content:encoded><![CDATA[<p>Sorry I can't spend a lot of time on your model this motning. <br /><br />It would appear that your model has a gap under it, and that gap is filled with supports, the lines are part of the support<br /><br />I have turned supports off and crudely added some material to fill most of the base and  changed infill to HEX<br /><br />and this is what I get....   </p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/12/Wood-low-modified.jpg"><img class="alignnone size-full wp-image-147709" src="https://forum.prusa3d.com/wp-content/uploads/2022/12/Wood-low-modified.jpg" alt="" width="409" height="413" /></a><br /><br />I don't know if this helps<br /><br />regards Joan<br /><br /><br /><br /></p>
<div id="wpfa-147710" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.prusa3d.com/wp-content/uploads/wpforo/default_attachments/1670485421-wood_low_warp-JT.zip" target="_blank" title="wood_low_warp-JT.zip"><i class="fas fa-paperclip"></i>&nbsp;wood_low_warp-JT.zip</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629249</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629242</link>
                        <pubDate>Thu, 08 Dec 2022 06:03:44 +0000</pubDate>
                        <description><![CDATA[The simple answer is you can’t. It is not an option. What’s the problem with it doing that ?  It’s designed to give better adhesion for the support to the build plater and the 90% density re...]]></description>
                        <content:encoded><![CDATA[<p>The simple answer is you can’t. It is not an option. <br />What’s the problem with it doing that ?  It’s designed to give better adhesion for the support to the build plater and the 90% density really helps with that. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629242</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629232</link>
                        <pubDate>Thu, 08 Dec 2022 01:36:34 +0000</pubDate>
                        <description><![CDATA[btw. I replied with my project file and some more info, but for some reason that post shows &quot;awaiting moderation&quot; and hasn&#039;t shown up yet in the thread]]></description>
                        <content:encoded><![CDATA[<p>btw. I replied with my project file and some more info, but for some reason that post shows "awaiting moderation" and hasn't shown up yet in the thread</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629232</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629231</link>
                        <pubDate>Thu, 08 Dec 2022 01:34:35 +0000</pubDate>
                        <description><![CDATA[I just noticed what you are using is infill, my problem is regarding support structures]]></description>
                        <content:encoded><![CDATA[<p>I just noticed what you are using is infill, my problem is regarding support structures</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629231</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629230</link>
                        <pubDate>Thu, 08 Dec 2022 01:26:04 +0000</pubDate>
                        <description><![CDATA[Thanks for your quick reply. Must be some other conflicting setting then. But I thought I just started with the default generic PLA ...
Your screenshot is exactly what I want. I added the z...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for your quick reply. Must be some other conflicting setting then. But I thought I just started with the default generic PLA ...</p>
<p>Your screenshot is exactly what I want. I added the zipped project, if you could double check on your end that would be great.</p>
<p>edit: i can't get the attachment to show up, its always gone after I saved the post :/ I also always have to wait for "moderation", idk if I can't upload files because I'm too new or so</p>
<p>this is the share link from my onedrive:</p>
<p>https://1drv.ms/u/s!AodlzgWfM1hfgv9cR4erC2wi3uNg2A?e=AST7xP</p>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629230</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629229</link>
                        <pubDate>Thu, 08 Dec 2022 01:15:00 +0000</pubDate>
                        <description><![CDATA[Strange, I tried to emulate this quickly, I loaded a simple cylinder into Prusa Slicer gave it Hex infill, and set zero bottom and top layers, 
And I got 
Could you please share your proje...]]></description>
                        <content:encoded><![CDATA[<p>Strange, <br />I tried to emulate this quickly, <br />I loaded a simple cylinder into Prusa Slicer gave it Hex infill, and set zero bottom and top layers, </p>
<p>And I got <br /><a href="https://forum.prusa3d.com/wp-content/uploads/2022/12/Hex-Infill.jpg"><img class="alignnone size-medium wp-image-147691" src="https://forum.prusa3d.com/wp-content/uploads/2022/12/Hex-Infill-600x500.jpg" alt="" width="600" height="500" /></a></p>
<p>Could you please share your project file with us? <br />File, Save Project As, save with a suitable name, <br />this will create a .3mf file. <br /><br />I also tried the model with a brim, still no lines across the bottom. <br /><br />then I tilted the model a tiny bit... and  I got lines, but they were blue Overhang perimeter lines, not green infill lines... </p>
<p>then zip compress the file and add the compressed file to your next post. <br />Regards Joan</p>
<div id="wpfa-147692" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="Hex-Infill.zip" href="//forum.prusa3d.com/wp-content/uploads/wpforo/default_attachments/1670462100-Hex-Infill.zip" target="_blank" rel="noopener"> Hex-Infill.zip</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629229</guid>
                        <title>How to get rid of different support pattern for first layer</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629227</link>
                        <pubDate>Thu, 08 Dec 2022 00:32:16 +0000</pubDate>
                        <description><![CDATA[I played with all parameters I can see in the support/expert section. But I can&#039;t get rid of this &quot;raft style&quot; first support layer. I can change the density, but how can I completely disable...]]></description>
                        <content:encoded><![CDATA[<p>I played with all parameters I can see in the support/expert section. But I can't get rid of this "raft style" first support layer. I can change the density, but how can I completely disable it? I want the support pattern to start right away according to my selection. E.g. in the screenshot example I want it to be a honeycomb starting with layer 1. At the moment 1st layer are some lines that don't fit the rest, then there are 2 layers nothing, honeycomb starts at layer 4:</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/12/slicer_support-1.png"><img class="alignnone size-full wp-image-147690" src="https://forum.prusa3d.com/wp-content/uploads/2022/12/slicer_support-1.png" alt="" width="1549" height="774" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-to-get-rid-of-different-support-pattern-for-first-layer/#post-629227</guid>
