How to get duration and filament usage on CLI?
Nia
 Nia
(@nia)
I'm trying to use the prusa-slicer cli interface to generate time and filament usage estimates for a lot of stl files in a big project of mine.
I can slice the stl files successfully, but I don't see any ways to get the resulting time and filament usage on stdout and didn't spot anything in the help output.
Any hints?
Best Answer by Diem:
One workaround is to include it in the gcode file name with
--output-filename-format
(you will need to use --help-fff if you don't see this in your -help output.)
Or, if you want to capture the info for a database the values are in every text format g-code file in the comment section at the end.  So you could pipe the output file through grep or use a custom post-processing script...
Napsal : 12/03/2026 8:32 pm
Napsal : 13/03/2026 3:33 am
1 lidem se líbí
Nia
 Nia
(@nia)
RE: How to get duration and filament usage on CLI?
Great, thanks. I'll pull it out of the comments of the gcode file!
Napsal : 13/03/2026 4:02 pm
I also did this for my g-code library. There is a function called estimate_print which will return an object that encapsulates time, length and weight. It's in Python. If not comfortable with Python REPL I could be convinced to create shell script (or PowerShell for Windows)
pip install gcode-lib
import gcode_lib as gl
# Load and estimate
 # Works with both binary and ascii gcode
gf = gl.load("my_print.bgcode")
 # auto-detect filament type
est = gl.estimate_print(gf.lines)
print(f"Print time:      {est.time_hms} ({est.time_seconds:.0f}s)")
print(f"Filament length: {est.filament_length_m:.2f} m")
print(f"Filament weight: {est.filament_weight_g:.1f} g")
# Use a different filament type
est = gl.estimate_print(gf.lines, filament_type="PETG")
# Or specify density and diameter directly
est = gl.estimate_print(gf.lines, filament_density=1.27, filament_diameter=1.75)
Napsal : 14/03/2026 5:31 pm
Nia
 Nia
(@nia)
interesting, thanks for sharing. my python script now just calls prusa-slicer, then reads those comments. that's enough for me for now, I'll keep it in the back of my mind in case I need more gcode related things in my code tho.
Napsal : 14/03/2026 8:51 pm
