How to determine exact diameters of ring model for perfectly conical infill?
greylock23
(@greylock23)
I'd like to make a ring that is exactly 4 layers thick from the inside out and give me 100% infill. As in 4 perfect circles that just touch on each side.
Looking at Prusa slicer I see I can set infill to 100% and then select concentric for fill pattern... But how do I determine the inner/outer diameter relationship for the model itself?
I see that my layer widths are 0.45mm. This makes me think I should set the outer diameter to be 3.6mm more than the inner diameter. because each layer is repeated side to side and 8x0.45mm=3.60mm.
Is this correct or is there some amount of overlap I need to account for as well?
Veröffentlicht : 08/12/2021 4:31 am
John
 John
(@john-6)
RE: How to determine exact diameters of ring model for perfectly conical infill?
look in the perimeter settings and you can see a dimension for each number of perimeter - that might help
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Veröffentlicht : 08/12/2021 5:37 am
greylock23
(@greylock23)
The perimeters can be adjusted there but knowing how many only helps if I know how wide they will be!
I suppose I could alter the number of horizontal shells solid layers to be the same as the overall number of layers in the model to force it to make everything continuous...
I mean I basically want to do a spiral vase but multiple layers thick and base the whole thing off the  outer diameter. These fit down into something else so I only care about the OD and having it be 100% solid.
Diese r Beitrag wurde geändert Vor 4 years von greylock23
Veröffentlicht : 08/12/2021 8:15 pm
sylviatrilling
(@sylviatrilling)
You might find this other g-code generator of interest:  http://fullcontrolgcode.com/
Mk3S+,SL1S
Veröffentlicht : 08/12/2021 9:42 pm
