How to copy the entire Prusaslicer configuration from one compute to another?
zapta
(@zapta)
I have Prusaslicer installed on one Window 10 machine and I would like to clone it's entire configuration on another Windows 10 machine.
Any suggestion how to do that?
Also, anybody knows where Prusaslicer keeps its configuration on Windows 10?
Napsal : 31/05/2021 3:57 pm
Ringarn67
(@ringarn67)
RE: How to copy the entire Prusaslicer configuration from one compute to another?
@zapta
Prusaslicers config files,
In Prusaslicer, "Help", "Show Configuration Folder"
How to export all settings
In Prusaslicer, "File", "Export", "Export Config Bundle"
How to import all settings
In Prusaslicer, "File", "Import", "Import Config Bundle" (be careful, cause it may be overwrite your current settings)
An excellent page about PS config files, https://projects.ttlexceeded.com/3dprinting_prusaslicer.html
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Napsal : 31/05/2021 4:44 pm
1 lidem se líbí
zapta
(@zapta)
Thanks @ringarn67!  This is exactly what I was looking for.
Napsal : 31/05/2021 4:54 pm
The config bundle only contains any custom profiles.  It does not contain any of the system ones.  To get those you have to use the first method mentioned of copying the folder or just use the wizard to get them like on a new install and then use the import config bundle to get all your own.
Napsal : 31/05/2021 6:44 pm
Ringarn67
(@ringarn67)
@neophyl
Thank YOU, didn´t know that 👍
Napsal : 31/05/2021 7:09 pm
