How to copy object from one prusa Slicer window to another?
Madman
(@madman)
I am ususally creating objects in Fusion 360 that have more elements than one. However, Fusion 360 can only take one object and create an STL from it and sending it to prusa slicer. When having two objects, but wanting to print them in one go, I have then two open prusa slicers and cannot move or copy object from window 1 to window 2. I always have to export it as STL and import it as STL in the other one - not nice. I wish there was another way. Perhaps I have not yet found the functionality or there is none.
How do you do this? Did I miss anything?
Thanks for any advice!
Best regards,
Oliver
Publié : 12/09/2023 7:38 am
PS will always import objects individually but if defined as parts they stay together.
Publié : 12/09/2023 10:59 am
RE: How to copy object from one prusa Slicer window to another?
I think this is a limitation in Fusion 360. I usually just select the bodies/components I want to export and use save as mesh to turn them into STLs, which I then load into Prusaslicer. To my knowledge you can't copy/paste across instances of PS.
Publié : 12/09/2023 11:12 am
1 personnes ont aimé
