        How to change temperature at different points during a print?
Hi all,
So I'm wanting to print a temperature tower so I can see at what temperature I should be printing some new PLA filament I received. However, I'm not sure where you would put these options in to PrusaSlicer to change the temperature at a specific point. Does anyone have some advice on how to do this?
Thanks!
                            Posted : 03/08/2019 5:32 pm
                    RE: How to change temperature at different points during a print?
AFAIK the only way to do this is by programming the temperature changes in the layer change g-code. Check out this Thingiverse item's notes on how to do this:
https://www.thingiverse.com/thing:2729076
It is helpful to know and understand the programming concept of "If...Then" statement structures.
See my (limited) designs on:
                            Posted : 03/08/2019 5:58 pm
