					                		How remove wipe tower from layout when only one color being used - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/</link>
                <lastBuildDate>Mon, 13 Apr 2026 13:32:28 +0000</lastBuildDate>
                        <title>RE: How remove wipe tower from layout when only one color being used</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718890</link>
                        <pubDate>Wed, 14 Aug 2024 13:17:25 +0000</pubDate>
                        <description><![CDATA[Hi, Robin. Thank you for your help. What is an MMU?]]></description>
                        <content:encoded><![CDATA[<p>Hi, Robin. Thank you for your help. What is an MMU?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Alfredo Medina</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718890</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718876</link>
                        <pubDate>Wed, 14 Aug 2024 11:11:54 +0000</pubDate>
                        <description><![CDATA[If you have an MMU you can use the &quot;MMU single mode&quot; printer profile to achive the same. (no wipetower)Also: this profile makes the printer (LCD) ask for the filament to load prior printing,...]]></description>
                        <content:encoded><![CDATA[<p>If you have an MMU you can use the "MMU single mode" printer profile to achive the same. (no wipetower)</p><p>Also: this profile makes the printer (LCD) ask for the filament to load prior printing, so you do not need to select it in Slicer. (or wonder which filament an older code-file wants to load)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Robin</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718876</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718759</link>
                        <pubDate>Tue, 13 Aug 2024 16:15:35 +0000</pubDate>
                        <description><![CDATA[Thanks a lot, @Neophy , with your help, I was able to find the option to disable the wipe tower.I am posting this image in case it helps another person after me.About my printer, it is an Or...]]></description>
                        <content:encoded><![CDATA[<p>Thanks a lot, @Neophy , with your help, I was able to find the option to disable the wipe tower.</p><p>I am posting this image in case it helps another person after me.</p><p>About my printer, it is an Original XL with 5 tools. Thanks again. I am a newbie.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/08/3e0cd09a-2024-08-13_12-11-28.jpg"><img class="alignnone size-medium wp-image-169482" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/08/3e0cd09a-2024-08-13_12-11-28-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718759</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718753</link>
                        <pubDate>Tue, 13 Aug 2024 15:19:17 +0000</pubDate>
                        <description><![CDATA[The setting you are looking for is under the Print Profile not the printer profile.  Also its a yellow coded setting so you must be in Advanced or Expert mode to see it.You haven&#039;t mentioned...]]></description>
                        <content:encoded><![CDATA[<p>The setting you are looking for is under the Print Profile not the printer profile.  Also its a yellow coded setting so you must be in Advanced or Expert mode to see it.</p><p>You haven't mentioned what printer you are using or the profiles you have installed etc but from 5 tool I have to make the assumption that's its a 5 tool XL.  I just installed that printer and the wipe tower setting is there  in the Print Settings as normal.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718753</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718663</link>
                        <pubDate>Mon, 12 Aug 2024 22:18:10 +0000</pubDate>
                        <description><![CDATA[Hi. My printer does have multiple extruders, but the Slicer software does not have that option Multiple Extruders, but individual settings for each of the 5 tools. So, the question remains. ...]]></description>
                        <content:encoded><![CDATA[<p>Hi. My printer does have multiple extruders, but the Slicer software does not have that option Multiple Extruders, but individual settings for each of the 5 tools. So, the question remains. Where do I go to remove that wipe block? I cannot select it and delete it, and I don't have that option Multiple Extruders&gt;Wipe Tower&gt; under Print Settings. Any help would be appreciated. Thanks.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-718663</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-578617</link>
                        <pubDate>Fri, 11 Feb 2022 07:37:15 +0000</pubDate>
                        <description><![CDATA[Just go to Print Settings&gt;Multiple Extruders&gt;Wipe Tower&gt;Enable and untick the box.]]></description>
                        <content:encoded><![CDATA[<p>Just go to Print Settings&gt;Multiple Extruders&gt;Wipe Tower&gt;Enable and untick the box.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-578617</guid>
                        <title>How remove wipe tower from layout when only one color being used</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-578596</link>
                        <pubDate>Fri, 11 Feb 2022 07:00:52 +0000</pubDate>
                        <description><![CDATA[I need to print a nearly full build plate with 50 copies of a small part.PrusaSlicer assumes, since I have an MMU, that it needs a wipe tower, and reserves a huge area for it, which is then ...]]></description>
                        <content:encoded><![CDATA[<p>I need to print a nearly full build plate with 50 copies of a small part.</p><p>PrusaSlicer assumes, since I have an MMU, that it needs a wipe tower, and reserves a huge area for it, which is then not available for arranging my parts for printing.</p><p>It ought to see that no color switches are being done and not plan a wipe tower.</p><p>How can I get rid of the wipe tower? </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>DaveGadgeteer</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-remove-wipe-tower-from-layout-when-only-one-color-being-used/#post-578596</guid>
