					                		How does an ol&#039; dummy like me change the support settings? - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/how-does-an-ol-dummy-like-me-change-the-support-settings/</link>
                <lastBuildDate>Fri, 17 Apr 2026 00:53:46 +0000</lastBuildDate>
                        <title>How does an ol&#039; dummy like me change the support settings?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/how-does-an-ol-dummy-like-me-change-the-support-settings/#post-766097</link>
                        <pubDate>Thu, 02 Oct 2025 23:08:29 +0000</pubDate>
                        <description><![CDATA[I want to make the supports easier to remove, and I found some settings (by user bobstro) that are supposed to be good:0.25mm z distance.75% xy distance.3mm support spacing.4 interface layer...]]></description>
                        <content:encoded><![CDATA[<p>I want to make the supports easier to remove, and I found some settings (by user bobstro) that are supposed to be good:</p><p>0.25mm z distance.</p><p>75% xy distance.</p><p>3mm support spacing.</p><p>4 interface layers.</p><p>0.2mm interface layer spacing.</p><p>So far, so good. The problem is that I'm an old dog and have a hard time learning new tricks. I'm totally new to 3D printing, and I can't figure out exactly where these values need to be entered. For example: The 4 interface layers can be entered under "Top Interface Layers" or "Bottom Interface Layers", and the 0.25mm z distance can be entered under "Raft Contact Z distance", "Top Contact Z distance" or "Bottom Contact Z distance". I just don't know the difference, and I suspect that I could make a mess if I enter them in the wrong place.</p><p>Also: Do I have to change the settings for all print options (ie from 0.05mm ultradetail to 0.30mm draft), or is there a way to enter them as user default values?</p><p>I would greatly appreciate some help with this! I'm at a total loss, since I don't have any experience and I'm not familiar at all with the nomenclature. If you use these settings, a screenshot would probably be more helpful than anything! </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Essebo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/how-does-an-ol-dummy-like-me-change-the-support-settings/#post-766097</guid>
