How do I automatically switch to a new filament roll when the filament roll runs out?
How do I configure a Prusa slicer with an MMU3 to automatically switch to a different roll when a filament roll runs out?
Prusa Core One
Opublikowany : 26/09/2025 2:10 pm
RE: How do I automatically switch to a new filament roll when the filament roll runs out?
Hi Richard,
You have to do this on the printer. When you load the file and the menu askes you if spool ?? is correct in that menu use the knob to go up to the spools and then push the button that you want to share with. In the bottom of the screen it will say share spools and you highlight and click it then move on. This has to be done manually and you cannot use Prusa Connect.
Opublikowany : 26/09/2025 8:36 pm
