High speed settings for Core 1+
roontoon
(@roontoon)
Just got a core 1+ and have done several files and some of the demos that came with it. it seems that the files that came with the machine were sliced with very high speeds set which the machine seemed to handle but I don't see any of there fast setting files that the demos had. are there a set of preset settings that are available to take advantage of the machines speed. TIA.
Opublikowany : 04/05/2026 8:05 pm
Cédric
(@cedric)
RE: High speed settings for Core 1+
If im in a hurry i just run the fast profile and then crank it up even more on the printer, by just setting the speed to 125 or 150%, try it out, quite hectic. Theres definitely a better way to make a fine tuned high speed profile, but im to lazy for that.
Opublikowany : 05/05/2026 1:33 pm
1 ludzie polubili
jan.d.slay
(@jan-d-slay)
Posted by: @cedric
I wouldn't have done it any differently either.
Opublikowany : 05/05/2026 4:43 pm
mnentwig
(@mnentwig)
The challenge is more on the extruder side than moving the head along its trajectory in shorter time.
Don't be shy to crank up speed to 300 % on test prints, I've never seen it skip steps (the firmware's acceleration and speed ceiling should rule that out).
It puts more stress on the printer, though, so don't be surprised if non-threadlocked screws come loose faster.
Opublikowany : 05/05/2026 5:35 pm
