Help? Irregular Layers
Hello everyone! I've tried everything and I can't get rid of the irregularities between layers. This only happens when I add more than one perimeter to the model. I've already changed the perimeter overlay, speed, flow, layer width... you can clearly see the difference in wall quality between the photos (one with 1 perimeter and the other with 3 perimeters). Thank you so much.
Printer: Artillery Genius
Material: PLA
Temperature: 210°C
Nozzle: 0.5 mm
Layer: 0.24 mm
Ext. Perimeter Vel.: 30mm/s
Int. Perimeter Vel.: 40mm/s
Postato : 10/09/2021 2:10 am
Whats the models wall thickness, as it was modeled?
The Filament Whisperer
Postato : 10/09/2021 4:34 am
