Height range modifier - Keeping feed rate constant but increase speed
jonas-3
(@jonas-3)
I have made a model(a simple square) where the bottom half is printed with 1 mm layer height. The top half is reduced to 0.5 mm layer height. Looking at the G-code I can see that the  speed is constant when going from 1mm to 0.5mm. What changes is the feed rate which drops with half which makes sense.
Is this the normal way of dealing with different layer height in a model?
What I would prefer was to have a constant feed rate and a variable speed. The speed would double when going from 1 mm to 0.5mm.
Is there a reason this is not the default way to do it, and can it even be done with PrusaSlicer?
I have a huge extruder mounted on a robot and need to print large items so it is important to have the Extruder pushing out as much material as possible.
Publié : 08/01/2020 2:07 pm
RE: Height range modifier - Keeping feed rate constant but increase speed
Are you using Prusa printer equipment or a different set up?
Have you configured Prusa Slicer to match your printers melt rate, and maximum print speeds etc.? if the slicer doesn't know about your huge extruder, it won't be able to use the capability!
it may be that your current settings are holding back the flow performance on the 1mm layer height as well as stifling the lower layer height  travel speed performance!
Publié : 08/01/2020 2:56 pm
jonas-3
(@jonas-3)
Thank your for your suggestions. It help me in the right direction - I think
I'm using a custom setup.
Okay so I tried setting every "Speed for print moves" to 0 - which means i'm using Autospeed. I then set the Max Print speed to a 3 mm/s (I know this is very low but when I run the Gcode through my robot software (robodk) the values becomes appropriate) I don't know what the Max volumetric speed is as i guess it is as off as the max print speed. I keept i at 0
With these settings the values in the Gcode for the speed is F 97.4742 for the 1 mm layer height and and F180 for the 0.5 mm layer height. Not double up but close.
Logically one would assume the speed for the 0,5mm layer to be x2. is there any setting that might effect that it is not?
Publié : 09/01/2020 12:29 pm
Sembazuru
(@sembazuru)
Posted by: @jonas-3
Your results after changing the max print speed to 3mm/s seems to track. the F180 value is in mm/min. 180mm/min = 3mm/s.
See my (limited) designs on:
Publié : 09/01/2020 6:03 pm
