Height Range Modifers
Yurtle Ahern
(@yurtle-ahern)
Hello,
My search didn't get me an answer so hopefully someone here can help.
I want to print a coaster with the logo face down to get the texture from the build plate. The layer height is set to the default 0.2mm.
I want to use the height range modifier to print the first layer in 0.15 to get  little more detail but then go back to 0.2 for the rest of the print to speed it up.
I have the start height at 0mm, Stop height at 0.15mm, Layer Height at 0.15mm.
Would these settings be correct?
Posted : 26/11/2025 9:49 am
RE: Height Range Modifers
If all you want to do is print the first layer at 0.15, you don't need height range modifiers.
Print Settings>Layers and perimeters>Layer Height>First layer height and set it to 0.15.
After slicing, you can use Preview and go to Legemd>Height to check that everything prints as expected.
Your settings wouldn't work as by default the first layer height is 0.2 mm.
Posted : 27/11/2025 12:14 am
