					                		Gcode Speed Syntax - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/gcode-speed-syntax/</link>
                <lastBuildDate>Sat, 25 Apr 2026 03:23:30 +0000</lastBuildDate>
                        <title>Gcode Speed Syntax</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/gcode-speed-syntax/#post-155328</link>
                        <pubDate>Fri, 26 Jul 2019 18:45:30 +0000</pubDate>
                        <description><![CDATA[Hi, firstly I need to mention that I am stuck using an older version of Marlin and that I am aware some of these issues may be fixed in newer versions.My main issue is regarding the placemen...]]></description>
                        <content:encoded><![CDATA[<p>Hi, firstly I need to mention that I am stuck using an older version of Marlin and that I am aware some of these issues may be fixed in newer versions.</p><p>My main issue is regarding the placement of the F__ speed parameter on its own line with G1: "G1 F500" before the actual movement "G1 X_ Y_" line. My firmware won't recognize an "F" without a specified axis in the same line and ignores it. For example:</p><p>G1 E1 F2000<br />G1 F500<br />G1 X97.362 Y74.737 E1.65204<br />G1 X101.000 Y82.093 E1.65195<br />G1 X97.482 Y82.093 E0.79009<br />G1 E-1.000 F2000<br />G1 X83.327 Y82.093 F1500<br />G1 E1.000 F2000<br />G1 F500<br />G1 X78.507 Y82.093 E1.08246</p><p>I want to print at F500 but it never does because the printing moves only adopt the previous valid line with F2000. I have tried slicing with the different firmware flavors but they all seem to do this. Can there be an option to place the F parameter in the first G1 line along with the axes instead of by itself?</p><p>My other request is that there be a separate option for specifying Z movement speed. Right now it seems coupled with the X/Y "Speed for non-print moves", and the only way to make it lower is to set the machine speed limits. Thanks.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>noah</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/gcode-speed-syntax/#post-155328</guid>
