function to fall on the mat
Do you know how I can turn off the function of falling on the mat?
I need to lift the object above the pad.
Thx
Thx
Yes!
Left-Click Part, Right-click part -> Add Part -> Cylinder, Resize cylinder to X=0,05 Y0,05 and Z200 in right pane with lock "Unlocked"
Click Part, (NOT Generic-Cylinder) in right pane, now you can move Part to wherever you like 😊
PS is unable to slice "Generic-Cylinder" so it won't disturb
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
RE: function to fall on the mat
you want to print in mid air?
or do you want to print one item on top of another item?
inside the attached zipfile, there are two STL's "Brian Text" and "Keyfob"
if you extract the files, and then load both files into slicer, slicer will typically put them both, 'Centred' on the build plate,
so Brian Text, will be inside Keyfob... which is a bit rubbish...
on the plater view, if you press Ctrl + A
you will select all parts, they should turn green, on the screen...
Now right click on the keyfob in Plater and you should see a menu option, to 'Merge' these two items.
the right hand dialog box should now show the items are merged, and show the part names below
If you click on the "Brian Text" item, you should be able to manipulate the position of the text relative to the keyfob...
as shown in the image above...
I hope this helps...
Thank you
it helped me a lot.
I didn't know it was enough to merge objects.
Everything is working now.
Thanks again 🙂
Glad to help
Joan
