Full reinstall
stlcoug
(@stlcoug)
Full reinstall
Im getting this error when i try to run the configuration wizard.
11:51:20: Internal error: Cannot load Vendor Config Bundle `PrusaResearch`: File not found: `"C:\Users\Owner\AppData\Roaming\PrusaSlicer\vendor\PrusaResearch.ini"`.
Is there a way I can do a clean install where it will pull all the files it needs to install properly?
I have uninstalled and reinstalled twice.
This topic was modified 5 years temu by stlcoug
Opublikowany : 07/01/2021 6:59 pm
Area51
(@area51)
RE: Full reinstall
I am a Linux user, but maybe the directory C:\Users\Owner\AppData\Roaming\PrusaSlicer exists before installing and should be deleted prior to reinstalling.
When uninstalling PrusaSlicer it keeps the profiles and setup files for reinstall. The path is found in Help->Show Configuration Folder, but that is no help if you can't get it to install... I know...
Opublikowany : 08/01/2021 12:02 am
RE: Full reinstall
Posted by: @stlcoug
Possibly the file is located in the cache folder:
Opublikowany : 08/01/2021 12:55 am
