First layer speed, per filament
kintner
(@kintner)
Is there a way to change the first layer speed for a specific filament? I have one that needs a slower first layer than most. I would rather not have to save a different printer profile just for this filament. I see all the speed settings on the filament tab, but no obvious way to change the first layer speed other than on the printer tab.
Thanks!
Posted : 19/11/2025 10:26 pm
You have already found the solution  - save a new profile; name it something meaningful and either delete it when the particular filament is used it or keep it for similar tricky filaments and tall narrow parts that need a really well stuck down first layer.
Posted : 20/11/2025 7:35 am
kintner
(@kintner)
RE: First layer speed, per filament
But that's not the solution I find intuitive or helpful. I don't want to have to remember which machine config I have to use for which filament, and take care to change it every time I use that filament, and have to deal with the mess that is config updates vs. old saved machine presets, etc...
Posted : 21/12/2025 6:42 pm
That why I specified meaningful names - one other method, not actually answering your question but addressing the underlying problem, is to make all the adjustments then save a project file - with a meaningful name - and all the settings will be saved along with the structure.
A sneaky alternative is to save a pro-forma project with all the settings and then when you next need those settings load the pro-forma project and import the part into the pre-adjusted environment.
Posted : 23/12/2025 12:28 pm
