File refuses to print
Page 2 / 2
Hello
(@hello)
RE: File refuses to print
Second file download this zip the extract file you need the second one
Posted : 25/04/2023 5:59 am
Billzilla
(@billzilla)
The file with the 'Y' in it is some kind of part for a Prusa printer and completely unrelated to what I'm doing.
Posted : 25/04/2023 6:00 am
Hello
(@hello)
I know but you don't get it if you attempt to print it and gets passed what couldn't before the we can fix old gcode if it still does same thing we know it's something with printer
Posted : 25/04/2023 6:02 am
René
(@rene-3)
Posted by: @billzilla
I've been trying to print a small part a few times today and the printer just stops & goes into cooldown just as it's about to do the first layer for the part. A few days back I was able to print the part with no problems, and (AFAIK) nothing has changed. I tested a different parts 3MF and that worked fine. Any ideas please?
What printer are you going to print this on?
Posted : 25/04/2023 7:05 am
Billzilla
(@billzilla)
I found the answer on Discord - "you have no position_min below 0 in stepper_z Move out of range: 113.587 4.063 -0.011 [6.604]to allow mesh hence the move out of range error, set it to position_min: -3"
Thanks for trying everyone.
Posted : 25/04/2023 7:20 am
René
(@rene-3)
I found it also,
The printer is a somewhat modified Cocoon Create (i3 clone, has a bowden drive and 32 bit SKR 1.3 in it) and it uses a BLTouch
Posted : 25/04/2023 8:32 am
Billzilla
(@billzilla)
Posted by: @rene-3
I found it also,
That was a while ago, it's now back to a direct-drive with an Orbiter and running Klipper firmware.
Posted : 25/04/2023 8:44 am
Page 2 / 2
