Filament name added to gcode file name
Tracy
(@tracy)
Is it possible to have the name of the filament appear in the generated gcode file name? I'm referring to Output filename format under Print Settings. I was hoping {filament_name} would do the trick but no such luck. I'm looking for an end result of something like this: 0.15mm_Prusa_PLA_1h43m.gcode.
Best Answer by Splinter-Printer:
try this one out:    {filament_settings_id[0]}
It gives you the name of the filamentsetting as you have saved it.
Napsal : 19/03/2020 9:15 pm
RE: Filament name added to gcode file name
Heres the entry from a mk3 optimal profile {input_filename_base}_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}.gcode
As you can see it uses {filament_type[0]}, I think the numerical designator is for the extruder number, so filament type from extruder 0.
Napsal : 19/03/2020 10:19 pm
Posted by: @tracy
With the parameter {notes} you can define and use free text (Print Settings -> Notes) in the output filename.
Napsal : 20/03/2020 12:39 am
You can use [filament_type] and [filament_vendor] in the Print Settings->Output options->Output file->Output filename format field. Unfortunately, there doesn't seem to be a field to enter actual vendor names in the Filament Settings tab.
Napsal : 20/03/2020 5:52 am
Tracy
(@tracy)
I appreciate the replies but unfortunately none of these are what I'm looking for. {filament_type[0]} produces "PLA" but not the vendor. Using {notes} requires multiple print settings that are identical except for the Notes field. {filament_vendor} would have been perfect except, as pointed out, there's no place on the Filament Settings tab to specify the vendor.
Napsal : 20/03/2020 8:09 pm
Splinter-Printer
(@splinter-printer)
Napsal : 10/05/2020 1:36 pm
2 lidem se líbí
Tracy
(@tracy)
Posted by: @splinter-printer
That works! Thank you!
Napsal : 10/05/2020 10:48 pm
Smokebeast
(@smokebeast)
Just wanted to say thank you.
I was trying to figure this out with the list of variables I found on the Prusa knowledge base but none of those worked. Your's worked perfectly!!
Now I no longer have to rename my gcode files each time I export, which is several times a day.
Napsal : 22/11/2023 9:06 am
