					                		Filament Maker’s recommended Print Speed is 20-40 mm/s. Now what? - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/filament-makers-recommended-print-speed-is-20-40-mm-s-now-what/</link>
                <lastBuildDate>Fri, 06 Mar 2026 08:49:27 +0000</lastBuildDate>
                        <title>RE: Filament Maker’s recommended Print Speed is 20-40 mm/s. Now what?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/filament-makers-recommended-print-speed-is-20-40-mm-s-now-what/#post-777502</link>
                        <pubDate>Sat, 10 Jan 2026 16:47:55 +0000</pubDate>
                        <description><![CDATA[Posted by: @dan82 I’m using Overture’s TPU 95A Filament.  Prusaslicer does not show a profile, just its high speed filament.  Overture provides a list of settings for the TPU 95a, bed temp, ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="563260" data-postid="777076" data-mention="dan82"><div class="wpforo-post-quote-author"><strong> Posted by: @dan82 </strong></div><p>I’m using Overture’s TPU 95A Filament.  Prusaslicer does not show a profile, just its high speed filament.  Overture provides a list of settings for the TPU 95a, bed temp, nozzle temp, etc…very straight forward.  However, the print speed of 20-40 mm/s is not so obvious what to change in Prusaslicer.  As you know, there are numerous print speed settings for various operations in prusaslicer.   Also, Overture doesn’t offer a profile for Prusaslicer.</p><p>I’m hoping I can better understand the interaction of all the print speed settings…it would be nice to just adjust one master number and have the others adjust accordingly.</p><p>I would appreciate any help on this.</p><p>Thanks, Dan </p><p> </p></blockquote><p>The master number you are referring to is the "Max volumetric speed". This is under Filaments -&gt; Advanced -&gt; Max volumetric speed. Adjusting this number depends on a various factors such as the filament type, printing temperature, nozzle diameter, nozzle type and in some cases even color. For TPU, I would just keep this number reasonably low. Also for TPU, as @foxrun3d pointed out, it must be dried before use. TPU is a water sponge. </p><p>As you your question. I generally print TPU with a 0.6mm non high-flow nozzle and .32mm layer height. With a print speed of 20-40mm/s, if we take the middle 30mm/s, this equates to a volumetric flow rate of 6.5 mm^3/s (30 mm/s * 0.68mm * 0.32mm)  For a 0.4m nozzle with 0.2mm layer height this comes out to around 3mm^3/s (30 * 0.45 * 0.2) </p><p>Bottom line though, is you don't need to (and shouldn't) print TPU fast. You also don't (and shouldn't) use a HF nozzle since if it clogs it's a PITA to unclog. Also, there is no benefit to printing TPU fast. Nor do you need detail for TPU so you can keep the layer lines large. </p><p>Start with the Generic Flex profile. For a 0.4mm nozzle this should set the flow rate to 2.5mm^3/s which is good enough. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/filament-makers-recommended-print-speed-is-20-40-mm-s-now-what/#post-777502</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/filament-makers-recommended-print-speed-is-20-40-mm-s-now-what/#post-777089</link>
                        <pubDate>Thu, 08 Jan 2026 01:22:50 +0000</pubDate>
                        <description><![CDATA[Not directly answering your question about speed adjustment but I&#039;ve printed a lot of overture TPU with the generic flex profile in Prusaslicer with excellent results. Just remember to dry y...]]></description>
                        <content:encoded><![CDATA[<p>Not directly answering your question about speed adjustment but I've printed a lot of overture TPU with the generic flex profile in Prusaslicer with excellent results. Just remember to dry your filament thoroughly. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/filament-makers-recommended-print-speed-is-20-40-mm-s-now-what/#post-777089</guid>
                        <title>Filament Maker’s recommended Print Speed is 20-40 mm/s. Now what?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/filament-makers-recommended-print-speed-is-20-40-mm-s-now-what/#post-777076</link>
                        <pubDate>Wed, 07 Jan 2026 22:11:15 +0000</pubDate>
                        <description><![CDATA[I’m using Overture’s TPU 95A Filament.  Prusaslicer does not show a profile, just its high speed filament.  Overture provides a list of settings for the TPU 95a, bed temp, nozzle temp, etc…v...]]></description>
                        <content:encoded><![CDATA[<p>I’m using Overture’s TPU 95A Filament.  Prusaslicer does not show a profile, just its high speed filament.  Overture provides a list of settings for the TPU 95a, bed temp, nozzle temp, etc…very straight forward.  However, the print speed of 20-40 mm/s is not so obvious what to change in Prusaslicer.  As you know, there are numerous print speed settings for various operations in prusaslicer.   Also, Overture doesn’t offer a profile for Prusaslicer.</p><p>I’m hoping I can better understand the interaction of all the print speed settings…it would be nice to just adjust one master number and have the others adjust accordingly.</p><p>I would appreciate any help on this.</p><p>Thanks, Dan </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Dan82</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/filament-makers-recommended-print-speed-is-20-40-mm-s-now-what/#post-777076</guid>
