					                		Extrusion width for certain parts at 50% - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/</link>
                <lastBuildDate>Wed, 11 Mar 2026 16:01:20 +0000</lastBuildDate>
                        <title>RE: Extrusion width for certain parts at 50%</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749717</link>
                        <pubDate>Tue, 13 May 2025 04:54:21 +0000</pubDate>
                        <description><![CDATA[Yes, exactly that, over layer height, that’s what the tooltip means , the percentage is based on the layer height and not nozzle width.]]></description>
                        <content:encoded><![CDATA[<p>Yes, exactly that, over layer height, that’s what the tooltip means , the percentage is based on the layer height and not nozzle width.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749717</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749714</link>
                        <pubDate>Tue, 13 May 2025 01:22:40 +0000</pubDate>
                        <description><![CDATA[Yup that did it. The tooltips doesn&#039;t tell you that. It says &quot;over first layer height.&quot;]]></description>
                        <content:encoded><![CDATA[<p>Yup that did it. The tooltips doesn't tell you that. It says "over first layer height."</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>travisstdenis</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749714</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749372</link>
                        <pubDate>Fri, 09 May 2025 21:14:15 +0000</pubDate>
                        <description><![CDATA[As I suspected and have now confirmed.  You really should read the tooltips :)  Hover over the first layer extrusion width field and have a read.  Your first layer is set to 115%.  When extr...]]></description>
                        <content:encoded><![CDATA[<p>As I suspected and have now confirmed.  You really should read the tooltips :)  Hover over the first layer extrusion width field and have a read.  Your first layer is set to 115%.  When extrusion widths are defined in percentages they are not computed against the nozzle diameter but against LAYER HEIGHT.  So first layer height is 0.2, your extrusion width is 0.23
This one gets loads of people.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749372</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749371</link>
                        <pubDate>Fri, 09 May 2025 21:06:15 +0000</pubDate>
                        <description><![CDATA[Sorry about that, it thought i had uploaded it.shellington]]></description>
                        <content:encoded><![CDATA[<p>Sorry about that, it thought i had uploaded it.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/0e4c1de4-shellington.zip">shellington</a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749371</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749370</link>
                        <pubDate>Fri, 09 May 2025 20:43:40 +0000</pubDate>
                        <description><![CDATA[Not from a snippet of gcode no.  We would need a copy of your prusa slicer project file to examine.  Use file&gt;save project as and then take the resulting .3mf file and ZIP it up.  If its ...]]></description>
                        <content:encoded><![CDATA[<p>Not from a snippet of gcode no.  We would need a copy of your prusa slicer project file to examine.  Use file&gt;save project as and then take the resulting .3mf file and ZIP it up.  If its not zipped the forum will silently drop the attachment.</p><p>I'm guessing you didn't zip it on your original post.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749370</guid>
                        <title>Extrusion width for certain parts at 50%</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749206</link>
                        <pubDate>Thu, 08 May 2025 23:39:50 +0000</pubDate>
                        <description><![CDATA[When the first layer of my print was coming out in a thin string and obviously not adhering to the plate, I checked the gcode and noticed that for certain parts, the extrusion width changes ...]]></description>
                        <content:encoded><![CDATA[<p>When the first layer of my print was coming out in a thin string and obviously not adhering to the plate, I checked the gcode and noticed that for certain parts, the extrusion width changes to .23mm or 50% of the regular extrusion width. I could not find in the print settings what could cause this and I'm hoping someone can help me find where to adjust this.</p><p>Here's a snippet of the gcode to show where it changes and the .3mf to see all the settings.</p><p>;TYPE:Support material interface<br />;WIDTH:0.45<br />G1 F1200G1 X-4.749 Y-3.966 E1.54241<br />G1 X-5.01 Y-4.284 E1.55634<br />G1 X-5.04 Y-4.655 E1.56894<br />G1 E.06894G92 E0<br />G1 X-6.162 Y-6.698 F7800<br />G1 E1.5 F1200<br />G1 X-6.008 Y-6.942 E1.50977<br />G1 X-4.147 Y-4.976 E1.6014<br />G1 X-4.056 Y-4.707 E1.61101<br />G1 X-4.123 Y-4.198 E1.62839<br />G1 X-8.097 Y-8.172 E1.81862<br />G1 X-7.871 Y-8.372 E1.82884<br />G1 X-7.52 Y-8.35 E1.84074<br />G1 X-6.393 Y-7.327 E1.89226<br />G1 X-6.557 Y-7.093 E1.90193<br />G1 X-7.205 Y-6.82 F7800<br />G1 F1200G1 X-7.655 Y-7.06 E1.91919<br />G1 X-7.958 Y-7.395 E1.93448<br />G1 X-8.332 Y-7.549 E1.94817<br />G1 X-8.738 Y-7.955 E1.9676<br />G1 X-8.775 Y-7.678 E1.97706<br />G1 X-8.523 Y-7.585 E1.98615<br />G1 E.48615<br />G92 E0G1 X-8.131 Y-8.563 F7800<br />G1 E1.5 F1200<br />;TYPE:Support material<br />;WIDTH:0.23<br />G1 X-8.425 Y-8.386 E1.50534<br />G1 X-8.876 Y-8.4 E1.51236<br />G1 X-8.57 Y-8.677 E1.51878<br />G1 X-8.344 Y-8.701 E1.52232<br />G1 X-8.155 Y-8.578 E1.52583<br />G1 E.02583<br />G92 E0G1 X-6.738 Y-8.709 F7800<br />G1 E1.5 F1200<br />G1 X-6.221 Y-8.366 E1.50965<br />G1 X-6.061 Y-8.097 E1.51452<br />G1 X-5.987 Y-7.788 E1.51946<br />G1 X-6.049 Y-7.472 E1.52447<br />G1 X-7.225 Y-8.515 E1.54892<br />G1 X-6.765 Y-8.713 E1.55671<br />G1 X-6.236 Y-7.752 F7800G1 F1200<br />G1 X-6.236 Y-8.063 E1.56155<br />G1 X-6.444 Y-8.341 E1.56695<br />G1 X-6.444 Y-8.05 E1.57148<br />G1 X-6.652 Y-8.233 E1.57579<br />G1 X-6.652 Y-8.483 E1.57968<br />G1 X-6.86 Y-8.508 E1.58294<br />G1 X-6.86 Y-8.305 E1.5861<br />G1 E.0861<br />G92 E0G1 X-5.164 Y-7.341 F7800<br />G1 E1.5 F1200</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/extrusion-width-for-certain-parts-at-50/#post-749206</guid>
