Exporting Supports from Command Line
Udo's 3D World
(@udos-3d-world)
Hi everyone - I already tried to look for this topic but I cannot find it at all. I want to export a model with its tree supports (for SLA printing) directly from the command line. I have simple models that do not need manual re-work during supporting but I also want to have the stl files. Is there a possibility? The only command line options I can see are --export-stl, which exports without support and --export-sla, which only puts it out as images and not as a 3d model.
The only way to do so is to do an export as sl1s and then load this again and save it as an stl - but this increases the model size a lot and decreases the quality... and I did not see that you cannot import sl1s files from the command line so this also does not work at all... Any other options?
Este debate ha sido modificado el hace 3 years por Udo's 3D World
Respondido : 11/01/2022 4:38 pm
PS is a slicer, the image stack is what the UV screen needs to print...
If you want to include custom supports in an stl or 3mf then that's a job for your design software.
Respondido : 11/01/2022 7:25 pm
Udo's 3D World
(@udos-3d-world)
RE: Exporting Supports from Command Line
I understand what you try to tell me but I beg to differ about this... Supports are something that belong to 3d printing and therefore I think it is paced better in the slicer.
My whole problem is not that it's not possible at all (you can export the supported stl by hand in prusa slicer) - I want to automate this and could not find the option in the command line interface. Can anyone Actually help me here? Thank you very much!
Respondido : 11/01/2022 7:34 pm
sylviatrilling
(@sylviatrilling)
If I understand what you are trying to do, you can do this in Meshmixer, which is free. See
Mk3S+,SL1S
Respondido : 11/01/2022 7:41 pm
Udo's 3D World
(@udos-3d-world)
I doubt that you understand what I want - meshmixer cannot do this from the command line... and that's the entire point I'm asking for: A command-line tool (that you can run automatically) that can create supports.
Respondido : 11/01/2022 8:06 pm
sylviatrilling
(@sylviatrilling)
Good luck with that.
Mk3S+,SL1S
Respondido : 12/01/2022 2:15 am
You are more likely to get an answer by asking at the Prusa Slicer github.  https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
If the command line doesnt support the export of the stl with the generated supports then you can also put in a feature request there too.
Respondido : 12/01/2022 7:52 am
1 les gusta
