Experiments on fixing seam issues on Arachne
Hey guys. I know arachne has been causing weird seams (for me too). However, I think I might have found a way to "fix" or improve this issue. Keep in mind that this has caused some uneven spots on the print as well.
Go into the printers section of PrusaSlicer and select the extruder. There, go to the retraction setting and change the "Deretraction extra-length" from zero to your length of retraction or a little less.
This edit changed the seam on the first picture on the green box to the seam on the orange box. Hope this helps.
Opublikowany : 19/10/2024 4:59 pm
