error message attempting to send g code
george
(@george-7)
I had my printer hooked to prusaslicer and the next day the wireless icon in the printer was gone.
I have it back now, added my printer in prusaslicer (I think) and when I attempted to send a file to the printer I got this error message.
Error uploading to print host:HTTP 401: 401: Unauthorized
Can someone point me in the right direction? I have no idea what isn't authorized
Respondido : 10/03/2024 6:44 pm
RE: error message attempting to send g code
No idea what printer you have. Instructions for configuring Prusalink and PrusaConnect and the Prusaslicer hookup are here https://help.prusa3d.com/article/prusa-connect-and-prusalink-explained_302608
You may also want to send a screenshot of your Prusaslicer Physical Printer configuration screen to get advice grounded in better data.
Respondido : 10/03/2024 11:12 pm
george
(@george-7)
oops.. I have a MK4 printer.
which tab or page in the printer settings?
Respondido : 11/03/2024 3:15 pm
I assumed that meant you had set up a physical printer here:
That should show you a dialog such as this one, where you can add the connection information from your printer (yours might look simpler as I added multiple nozzle configs).
If your problem is actually with the printer wifi or ethernet itself (printer not connecting to your network), I'll have to refer you to the links I posted before. I'm away from my printers for a few more weeks enjoying the warmer weather in the southern U.S.A., so I can't look at my printers to check how they're configured.
Esta publicación ha sido modificada el hace 2 years por
Respondido : 11/03/2024 10:52 pm
george
(@george-7)
I have that filled in and my printer is showing hooked to my network.
I obviously missed a step or filled something in wrong.
I will read the info you provided and give it another go.
enjoy your vacation.
Esta publicación ha sido modificada el hace 2 years por george
Respondido : 12/03/2024 1:03 pm
george
(@george-7)
Found a bit more info on the error message.
If I open the prusalink dashboard it shows the info on my printer. IE temps, if it's idle,etc
Could not connect to PrusaLink: HTTP 401: 401: Unauthorized
Respondido : 12/03/2024 1:54 pm
XL beta tester for far too long
(@xl-beta-tester-for-far-too-long)
Having this issue right now, still no solution... wow.
Respondido : 18/09/2024 9:10 pm
Mafke
(@mafke)
I got a 403 error many times, all I got to do before fixing it was getting the Octoprint API key and pasting it again in the prusa slicer settings...
Respondido : 22/05/2025 9:50 am
