					                		Error 6 when entering Printer&#039;s hostname - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/</link>
                <lastBuildDate>Sun, 19 Apr 2026 11:01:44 +0000</lastBuildDate>
                        <title>RE: Error 6 when entering Printer&#039;s hostname</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-756190</link>
                        <pubDate>Wed, 02 Jul 2025 18:29:35 +0000</pubDate>
                        <description><![CDATA[Hi all, future researchers, we fixed the problem! My issue seems to have been that Flatpak wasn&#039;t using the local network&#039;s DNS, instead trying to reach out of the network where my local pri...]]></description>
                        <content:encoded><![CDATA[<p>Hi all, future researchers, we fixed the problem! My issue seems to have been that Flatpak wasn't using the local network's DNS, instead trying to reach out of the network where my local printer obviously wasn't. To anyone else with the same problem try using the IP address of the printer instead.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Swizzel Stixx</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-756190</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-756183</link>
                        <pubDate>Wed, 02 Jul 2025 17:00:31 +0000</pubDate>
                        <description><![CDATA[Hi, thanks for replying.So my printer is actually called klipper.local, so I tried, “klipper.local”, worked for a while, but then prusaslicer updated and it broke again.]]></description>
                        <content:encoded><![CDATA[<p>Hi, thanks for replying.</p><p>So my printer is actually called klipper.local, so I tried, “http://klipper.local”, “klipper.local”, “http://klipper” worked for a while, but then prusaslicer updated and it broke again.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-756183</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-756173</link>
                        <pubDate>Wed, 02 Jul 2025 13:53:43 +0000</pubDate>
                        <description><![CDATA[`` means that you should replace it with the real address of the machine in the network which runs the klipper.
For example if you use something likethen use that
What&#039;s the addre...]]></description>
                        <content:encoded><![CDATA[<p>`` means that you should replace it with the real address of the machine in the network which runs the klipper.</p>
<p>For example if you use something like http://my-rasspery-pi.local then use that</p>
<p><br />What's the address you use to access the klipper?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>_KaszpiR_</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-756173</guid>
                        <title>Error 6 when entering Printer&#039;s hostname</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-746743</link>
                        <pubDate>Mon, 21 Apr 2025 13:33:30 +0000</pubDate>
                        <description><![CDATA[Hi all, I am trying to set up the function to upload Gcode to my klipper printer from the slicer, using version 2.9.2 Flatpak on Linux Mint 22.1. I tried the search function which found noth...]]></description>
                        <content:encoded><![CDATA[<p>Hi all, I am trying to set up the function to upload Gcode to my klipper printer from the slicer, using version 2.9.2 Flatpak on Linux Mint 22.1. I tried the search function which found nothing. I tried inputting the printer's hostname, `http://.local`, and got</p>
<p>`Could not connect to Moonraker: Couldn't resolve host name:Could not resolve host: .local`</p>
<p>as a response to pressing the test button. Any ideas on how to fix this please? I have searched the internet and perhaps flatpak apps can't see the network, as I can access the hostname from my web browser on the same computer just fine.</p>
<p>Thanks, Swizz</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/error-6-when-entering-printers-hostname/#post-746743</guid>
