					                		Entirely disable part cooling fan for a print - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/entirely-disable-part-cooling-fan-for-a-print/</link>
                <lastBuildDate>Wed, 10 Jun 2026 05:54:36 +0000</lastBuildDate>
                        <title>RE: Entirely disable part cooling fan for a print</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/entirely-disable-part-cooling-fan-for-a-print/#post-729625</link>
                        <pubDate>Thu, 12 Dec 2024 14:32:23 +0000</pubDate>
                        <description><![CDATA[Ah!  That would be it.  I didn&#039;t realize there was a &quot;fan speed&quot; setting under gcode preview.I don&#039;t own the IP, so I can&#039;t share the project, but I can now see the results of any changes to...]]></description>
                        <content:encoded><![CDATA[<p>Ah!  That would be it.  I didn't realize there was a "fan speed" setting under gcode preview.</p><p>I don't own the IP, so I can't share the project, but I can now see the results of any changes to the gcode for fan speed without having to manually dig through the gcode itself.  You are a lifesaver.  Thank you!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>chris.b46</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/entirely-disable-part-cooling-fan-for-a-print/#post-729625</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/entirely-disable-part-cooling-fan-for-a-print/#post-729619</link>
                        <pubDate>Thu, 12 Dec 2024 13:05:59 +0000</pubDate>
                        <description><![CDATA[It should be yes.  We could play 20 questions but if you save your project file from Prusa Slicer (File&gt;Save project as) and then ZIP it up and attach it here we can then look at ALL the ...]]></description>
                        <content:encoded><![CDATA[<p>It should be yes.  We could play 20 questions but if you save your project file from Prusa Slicer (File&gt;Save project as) and then ZIP it up and attach it here we can then look at ALL the settings as a project contains the models and more importantly a copy of the 3 profiles you currently are using.  You must zip it or the forum wont attch the file.</p><p>For example do you have Dynamic Fan speeds active ?  Those are a Red/Expert level setting so you wont even see those if you aren't in expert mode.  </p><p>Also what does the gcode preview show for the fan speed when you change the dropdown to Fan Speed ?  Again another question that wouldnt be needed with a project :)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/entirely-disable-part-cooling-fan-for-a-print/#post-729619</guid>
                        <title>Entirely disable part cooling fan for a print</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/entirely-disable-part-cooling-fan-for-a-print/#post-729600</link>
                        <pubDate>Thu, 12 Dec 2024 11:34:41 +0000</pubDate>
                        <description><![CDATA[Is it possible to entirely disable the part cooling fan for a print?  I am having trouble dialing in Varioshore TPU for maximum foaming, and I suspect it might be because no matter what I do...]]></description>
                        <content:encoded><![CDATA[<p>Is it possible to entirely disable the part cooling fan for a print?  I am having trouble dialing in Varioshore TPU for maximum foaming, and I suspect it might be because no matter what I do the fan is turning on during the print.  This cools down the filament as the bubbles are forming, resulting in smaller bubbles and a denser part.  The part is a thin membrane printed flat on the bed, so there is no need for any part cooling.</p><p>In Prusaslicer under the "Filaments" tab I have selected the following:</p><p>Keep fan always on: Unchecked</p><p>Enable auto cooling: Unchecked</p><p>Bridges fan speed: 0%</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/entirely-disable-part-cooling-fan-for-a-print/#post-729600</guid>
