Ender 3 V3 SE Support?
Nathan Hand
(@nathan-hand)
Miembro
Hi there everyone! just curious, has anyone heard anything on when the new Ender 3 V3 SE will be supported on PrusaSlicer? The only slicer with support for it is "Creality Print" and it is awful. Apologies if this has already been asked, I searched for it and couldn't find anything. Thanks!
Respondido : 10/09/2023 5:16 am
Hello
(@hello)
RE: Ender 3 V3 SE Support?
Not sure when officially supported but You can make a custom profile it's not to hard just set bed size start and end gcode which should be found in the current slicer few other things that's it
Respondido : 10/09/2023 9:31 am
Nathan Hand
(@nathan-hand)
Miembro
I've tried, but for some reason it just gets stuck after checking z-offset. It probably has something to do with the auto-leveling bed or something like that
Respondido : 10/09/2023 5:05 pm
Nathan Hand
(@nathan-hand)
Miembro
Update: Never mind, it just started working. I don't know what I did differently but it works now
Respondido : 10/09/2023 6:26 pm
Nikolas Šťastný
(@nikolas-stastny)
Miembro
Hi Nathan,
can you please share your profile?
Respondido : 23/09/2023 4:54 pm
MotoBitCrush
(@motobitcrush)
Miembro
Not OP, I also have no idea what I am doing tbh but this is what I got when importing/exporting:
Export from Creality:
[machine]
machine_name=Ender-3 V3 SE
machine_start_gcode=M220 S100 ;Reset Feedrate\nM221 S100 ;Reset Flowrate\n\nG28 ;Home\n\nG92 E0 ;Reset Extruder\nG1 Z2.0 F3000 ;Move Z Axis up\nG1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position\nM109 S[material_print_temperature_layer_0]\nG1 X10.1 Y145.0 Z0.28 F1500.0 E15 ;Draw the first line\nG1 X10.4 Y145.0 Z0.28 F5000.0 ;Move to side a little\nG1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line\nG92 E0  ;Reset Extruder\nG1 E-1.0000 F1800 ;Retract a bit\nG1 Z2.0 F3000 ;Move Z Axis up\nG1 E0.0000 F1800 \n
machine_end_gcode=G91 ;Relative positionning\nG1 E-2 F2700 ;Retract a bit\nG1 E-2 Z0.2 F2400 ;Retract and raise Z\nG1 X5 Y5 F3000 ;Wipe out\nG1 Z10 ;Raise Z more\nG90 ;Absolute positionning\n\nG1 X0 Y0 ;Present print\nM106 S0 ;Turn-off fan\nM104 S0 ;Turn-off hotend\nM140 S0 ;Turn-off bed\n\nM84 X Y E ;Disable all steppers but Z\n
material_print_temp_wait=false
material_print_temp_prepend=true
material_bed_temp_prepend=true
machine_width=220
machine_depth=220
machine_shape=rectangular
machine_height=250
machine_heated_bed=true
machine_center_is_zero=false
machine_extruder_count=1
machine_extruder_type=Proximal
extruders_enabled_count=1
machine_nozzle_temp_enabled=true
machine_nozzle_heat_up_speed=2.0
machine_nozzle_cool_down_speed=2.0
machine_fan_speed_up_time=0
machine_cds_fan_speed_up_time=0
machine_chamber_fan_exist=false
machine_cds_fan_exist=false
machine_LED_light_exist=false
machine_gcode_flavor=RepRap (Marlin/Sprinter)
machine_head_with_fans_polygon=[[-20,10],[10,10],[10,-10],[-20,-10]]
machine_nozzle_size=0.4
machine_max_feedrate_x=500
machine_max_feedrate_y=500
machine_max_feedrate_z=30
machine_max_feedrate_e=100
machine_max_acceleration_x=5000.00
machine_max_acceleration_y=5000.00
machine_max_acceleration_z=500.00
machine_max_acceleration_e=5000
machine_max_jerk_xy=10
machine_max_jerk_z=0.4
machine_max_jerk_e=5.0
machine_is_belt=false
has_preview_img=false
preview_img_type=png
screen_size=Sermoon D3
machine_support_slicer_type=FDM
[Extruder_0]
machine_nozzle_offset_x=0
machine_nozzle_offset_y=0
machine_extruder_start_code=
machine_extruder_end_code=
machine_extruder_cooling_fan_number=0
line_width=0.42
wall_line_width=0.42
wall_line_width_0=0.42
wall_line_width_x=0.45
skin_line_width=0.42
roofing_line_width=0.42
infill_line_width=0.45
skirt_brim_line_width=0.42
support_line_width=0.42
support_interface_line_width=0.42
support_roof_line_width=0.42
support_bottom_line_width=0.42
prime_tower_line_width=0.42
initial_layer_line_width_factor=110
initial_layer_line_width=0.46
retraction_enable=true
retraction_wipe=true
wipe_length=2
before_wipe_retraction_amount_percent=70
retract_at_layer_change=false
retraction_amount=0.8
retraction_speed=40
retraction_retract_speed=40
retraction_prime_speed=40
retraction_extra_prime_amount=0
retraction_min_travel=2.00
retraction_count_max=100
retraction_extrusion_window=0.80
limit_support_retractions=true
retraction_combing=noskin
retraction_combing_max_distance=30
retraction_during_traveling=false
travel_retract_before_outer_wall=true
travel_avoid_other_parts=true
travel_avoid_supports=true
travel_avoid_distance=0.625
layer_start_x=0.0
layer_start_y=0.0
retraction_hop_enabled=false
retraction_hop_only_when_collides=false
retraction_hop=0.2
retraction_hop_type=directlift
retraction_hop_after_extruder_switch=true
retraction_hop_after_extruder_switch_height=1
raft_surface_line_width=0.42
switch_extruder_retraction_amount=5.0
switch_extruder_retraction_speed=20
switch_extruder_prime_speed=20
switch_extruder_extra_prime_amount=0
Imported that into Prusa, this is the export:
# generated by PrusaSlicer 2.6.1+MacOS-arm64 on 2023-10-21 at 19:17:25 UTC
autoemit_temperature_commands = 1
avoid_crossing_curled_overhangs = 0
avoid_crossing_perimeters = 0
avoid_crossing_perimeters_max_detour = 0
bed_custom_model =
bed_custom_texture =
bed_shape = 0x0,200x0,200x200,0x200
bed_temperature = 0
before_layer_gcode =
between_objects_gcode =
bottom_fill_pattern = monotonic
bottom_solid_layers = 3
bottom_solid_min_thickness = 0
bridge_acceleration = 0
bridge_angle = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 60
brim_separation = 0
brim_type = outer_only
brim_width = 0
color_change_gcode = M600
colorprint_heights =
complete_objects = 0
cooling = 1
cooling_tube_length = 5
cooling_tube_retraction = 91.5
default_acceleration = 0
default_filament_profile =
default_print_profile =
deretract_speed = 0
disable_fan_first_layers = 3
dont_support_bridges = 1
draft_shield = disabled
duplicate_distance = 6
elefant_foot_compensation = 0
enable_dynamic_fan_speeds = 0
enable_dynamic_overhang_speeds = 0
end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
end_gcode = M104 S0 ; turn off temperature\nG28 X0  ; home X axis\nM84     ; disable motors\n
external_perimeter_acceleration = 0
external_perimeter_extrusion_width = 0
external_perimeter_speed = 50%
external_perimeters_first = 0
extra_loading_move = -2
extra_perimeters = 1
extra_perimeters_on_overhangs = 0
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_colour = ""
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 0
fan_below_layer_time = 60
filament_colour = #29B2B2
filament_cooling_final_speed = 3.4
filament_cooling_initial_speed = 2.2
filament_cooling_moves = 4
filament_cost = 0
filament_density = 0
filament_deretract_speed = nil
filament_diameter = 1.75
filament_load_time = 0
filament_loading_speed = 28
filament_loading_speed_start = 3
filament_max_volumetric_speed = 0
filament_minimal_purge_on_wipe_tower = 15
filament_multitool_ramming = 0
filament_multitool_ramming_flow = 10
filament_multitool_ramming_volume = 10
filament_notes = ""
filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
filament_retract_before_travel = nil
filament_retract_before_wipe = nil
filament_retract_layer_change = nil
filament_retract_length = nil
filament_retract_length_toolchange = nil
filament_retract_lift = nil
filament_retract_lift_above = nil
filament_retract_lift_below = nil
filament_retract_restart_extra = nil
filament_retract_restart_extra_toolchange = nil
filament_retract_speed = nil
filament_settings_id = "OEM v3 se_0.4 nozzle.ini"
filament_soluble = 0
filament_spool_weight = 0
filament_toolchange_delay = 0
filament_type = PLA
filament_unload_time = 0
filament_unloading_speed = 90
filament_unloading_speed_start = 100
filament_vendor = (Unknown)
filament_wipe = nil
fill_angle = 45
fill_density = 20%
fill_pattern = stars
first_layer_acceleration = 0
first_layer_acceleration_over_raft = 0
first_layer_bed_temperature = 0
first_layer_extrusion_width = 200%
first_layer_height = 0.35
first_layer_speed = 30
first_layer_speed_over_raft = 30
first_layer_temperature = 200
full_fan_speed_layer = 0
fuzzy_skin = none
fuzzy_skin_point_dist = 0.8
fuzzy_skin_thickness = 0.3
gap_fill_enabled = 1
gap_fill_speed = 20
gcode_comments = 0
gcode_flavor = reprap
gcode_label_objects = 0
gcode_resolution = 0.0125
gcode_substitutions =
high_current_on_filament_swap = 0
host_type = prusalink
idle_temperature = nil
infill_acceleration = 0
infill_anchor = 600%
infill_anchor_max = 50
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_overlap = 25%
infill_speed = 80
interface_shells = 0
ironing = 0
ironing_flowrate = 15%
ironing_spacing = 0.1
ironing_speed = 15
ironing_type = top
layer_gcode =
layer_height = 0.3
machine_limits_usage = time_estimate_only
machine_max_acceleration_e = 10000,5000
machine_max_acceleration_extruding = 1500,1250
machine_max_acceleration_retracting = 1500,1250
machine_max_acceleration_travel = 1500,1250
machine_max_acceleration_x = 9000,1000
machine_max_acceleration_y = 9000,1000
machine_max_acceleration_z = 500,200
machine_max_feedrate_e = 120,120
machine_max_feedrate_x = 500,200
machine_max_feedrate_y = 500,200
machine_max_feedrate_z = 12,12
machine_max_jerk_e = 2.5,2.5
machine_max_jerk_x = 10,10
machine_max_jerk_y = 10,10
machine_max_jerk_z = 0.2,0.4
machine_min_extruding_rate = 0,0
machine_min_travel_rate = 0,0
max_fan_speed = 100
max_layer_height = 0
max_print_height = 200
max_print_speed = 80
max_volumetric_extrusion_rate_slope_negative = 0
max_volumetric_extrusion_rate_slope_positive = 0
min_bead_width = 85%
min_fan_speed = 35
min_feature_size = 25%
min_layer_height = 0.07
min_print_speed = 10
min_skirt_length = 0
mmu_segmented_region_interlocking_depth = 0
mmu_segmented_region_max_width = 0
notes =
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 0
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhang_fan_speed_0 = 0
overhang_fan_speed_1 = 0
overhang_fan_speed_2 = 0
overhang_fan_speed_3 = 0
overhang_speed_0 = 15
overhang_speed_1 = 15
overhang_speed_2 = 20
overhang_speed_3 = 25
overhangs = 1
parking_pos_retraction = 92
pause_print_gcode = M601
perimeter_extruder = 1
perimeter_generator = arachne
perimeter_speed = 60
perimeters = 3
physical_printer_settings_id =
post_process =
print_host =
print_settings_id = OEM v3 se_0.4 nozzle.ini
printer_model =
printer_notes =
printer_settings_id = OEM v3 se_TEST 4.0noz
printer_technology = FFF
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
raft_contact_distance = 0.1
raft_expansion = 1.5
raft_first_layer_density = 90%
raft_first_layer_expansion = 3
raft_layers = 0
remaining_times = 0
resolution = 0
retract_before_travel = 2
retract_before_wipe = 0%
retract_layer_change = 0
retract_length = 2
retract_length_toolchange = 10
retract_lift = 0
retract_lift_above = 0
retract_lift_below = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 40
seam_position = aligned
silent_mode = 1
single_extruder_multi_material = 0
single_extruder_multi_material_priming = 1
skirt_distance = 6
skirt_height = 1
skirts = 1
slice_closing_radius = 0.049
slicing_mode = regular
slowdown_below_layer_time = 5
small_perimeter_speed = 15
solid_infill_acceleration = 0
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0
solid_infill_speed = 20
spiral_vase = 0
staggered_inner_seams = 0
standby_temperature_delta = -5
start_filament_gcode = "; Filament gcode\n"
start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n
support_material = 0
support_material_angle = 0
support_material_auto = 1
support_material_bottom_contact_distance = 0
support_material_bottom_interface_layers = -1
support_material_buildplate_only = 0
support_material_closing_radius = 2
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_contact_loops = 0
support_material_interface_extruder = 1
support_material_interface_layers = 3
support_material_interface_pattern = rectilinear
support_material_interface_spacing = 0
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 60
support_material_style = grid
support_material_synchronize_layers = 0
support_material_threshold = 0
support_material_with_sheath = 1
support_material_xy_spacing = 50%
support_tree_angle = 40
support_tree_angle_slow = 25
support_tree_branch_diameter = 2
support_tree_branch_diameter_angle = 5
support_tree_branch_diameter_double_wall = 3
support_tree_branch_distance = 1
support_tree_tip_diameter = 0.8
support_tree_top_rate = 15%
temperature = 200
template_custom_gcode =
thick_bridges = 1
thin_walls = 1
threads = 10
thumbnails =
thumbnails_format = PNG
toolchange_gcode =
top_fill_pattern = monotonic
top_infill_extrusion_width = 0
top_solid_infill_acceleration = 0
top_solid_infill_speed = 15
top_solid_layers = 3
top_solid_min_thickness = 0
travel_acceleration = 0
travel_speed = 130
travel_speed_z = 0
use_firmware_retraction = 0
use_relative_e_distances = 0
use_volumetric_e = 0
variable_layer_height = 1
wall_distribution_count = 1
wall_transition_angle = 10
wall_transition_filter_deviation = 25%
wall_transition_length = 100%
wipe = 0
wipe_into_infill = 0
wipe_into_objects = 0
wipe_tower = 0
wipe_tower_bridging = 10
wipe_tower_brim_width = 2
wipe_tower_cone_angle = 0
wipe_tower_extra_spacing = 100%
wipe_tower_extruder = 0
wipe_tower_no_sparse_layers = 0
wipe_tower_rotation_angle = 0
wipe_tower_width = 60
wipe_tower_x = 180
wipe_tower_y = 140
wiping_volumes_extruders = 70,70
wiping_volumes_matrix = 0
xy_size_compensation = 0
z_offset = 0
Looking that over, looks like the import/export process did not work 100% (bed size for example is wrong)
Esta publicación ha sido modificada el hace 3 years por MotoBitCrush
Respondido : 21/10/2023 7:22 pm
You cant directly import one into the other.  you have to manually figure out the equivalent settings.  They use totally different placeholders.    Also for things like start and end gcode blocks you have to convert those into the format and placeholder strings used too.
Respondido : 22/10/2023 9:33 am
MotoBitCrush
(@motobitcrush)
Miembro
Thanks for the knowledge, I followed directions on how I understood them and posted my results. Also went ahead and post my results incase it may be useful to someone else.
I started creating a spreadsheet script that converted using stuff that looked obvious but I thank you for mentioning the gcode stuff because that just means I need to wait for a hero to upload theirs or for it to become officially integrated. You saved me from posting another flop lol
Posted by: @neophyl
Respondido : 22/10/2023 1:37 pm
KoldDog
(@kolddog)
Miembro
Hello friends, I took a lot manually from Creality software and then did some tweaks after few prints and these are my results...prints quite reliably, but you can tweak it at hearts desire. I just started 3D Printing so if you see some bad piece of setting, just tell me. I took Ender V3 S1 as Template and for Filaments the generic ones. I haven't really gone into Expert settings, just the things I really recognized from Creality Slice naming system. I still play with it a little bit, but that's because the different models than the general settings. If you would suggest any other values I would appreciate. Also the Start and End of G-Code for printer is copied from Creality and at first print I got some error and needed to change I think [ into {. I hope the picture gallery works.
Esta publicación ha sido modificada el hace 3 years por KoldDog
Respondido : 25/11/2023 10:07 pm
KoldDog
(@kolddog)
Miembro
Respondido : 25/11/2023 10:12 pm
Karel Brož
(@karel-broz)
Miembro
Hi, i have a problem in:
M109
do you think, you could help me?
Thanks in advance.
Respondido : 28/11/2023 8:51 pm
Hi Karel,
what problem are you having with M109?
maybe this website will help.
Search on M109, there are examples.
Respondido : 28/11/2023 10:17 pm
KoldDog
(@kolddog)
Miembro
Hi, try changing the brackets [ into {, or vice versa, don't remember which are where, that worked for me. Look closely in the screenshot of M109 and you'll see the difference. Also maybe the Support interface spacing to 0.2 from 0.4, I had some problems detaching the supports lately
Respondido : 28/11/2023 10:34 pm
KoldDog
(@kolddog)
Miembro
Few settings tweaked to get better prints with PETG - no stringing now:
PETG bed 65°C -> 70°C
PETG retraction 1.5 mm -> 1.6 mm
PETG retraction speed 40 mm/s -> 42 mm/s
Seams "Aligned"
Skirt distance 3 mm -> 5mm
Support Interface pattern spacing 0.4 mm -> 0.2 mm ... was wrongly imported from creality by me
Respondido : 30/11/2023 9:36 pm
yaser_kose
(@yaser_kose)
Miembro
Senin gibi yapmaya çalıştım ama bu sayfayı geçemiyorum nasıl yapacağım
Respondido : 24/12/2023 6:27 pm
Denis Nazarov
(@denis-nazarov)
Miembro
Ender 3 V3 SE is terrible. The proprietary firmware does not give the desired quality, strong vibration of the Y-axis does not allow you to print at high speed. PrusaSlicer is just a slicer and it can't fix the situation. I put a klipper, calibrated pressure advance, adjusted flow and retract and got excellent quality, except for Y vibrations, but here you have to adjust input shaper.
But in doing so, I lost screen functionality and it's laying a brick. A small price to pay for good quality and printing speed ))
And now the Ender 3 V3 SE is beautiful ))))
Attached (link) are my profiles for PrusaSlicer. The files should be placed in %APPDATA%\PrusaSlicer. I remind you that I have Klipper installed, so there are Klipper commands in the starting G-Code
Respondido : 28/12/2023 11:02 am
Mauro Sergio
(@mauro-sergio)
Miembro
Hi bro, can you share please the guideline that you follow to make klipper correctly work on Ender 3 v3 SE, thanks a lot
Posted by: @denis-nazarov
Respondido : 08/01/2024 10:58 pm
